Old 05-02-2015, 01:14 AM   #1
lifeinak
72 door panels
Ok, so I finally got a nice of OEM plain Jane black door panels but I now need arm rests. Any opinions on who sells reproductions of high quality?? Also wondering if I can install wood grain inserts on these and details of what it requires. Maybe some pictures. I am looking at the aluminum reproductions at the truck shop and wondering if they are any good and also is there a trim ring required. Any help greatly appreciated. Thanks
lifeinak is offline   Reply With Quote
Old 05-02-2015, 01:43 PM   #2
lifeinak
Re: 72 door panels
Vetted please
Old 05-02-2015, 05:32 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: 72 door panels
You will need to drill the holes for the retaining ring to go into. It keeps the wood grain attached to the door (not reproduced). The new aluminum panels are good quality, though the wood grain pattern is not 100% authentic. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 05-02-2015, 08:24 PM   #4
lifeinak
Re: 72 door panels
Thanks Trevor, are you aware of a source for the retaining rings.
Old 05-02-2015, 08:45 PM   #5
71blksuper4x4
SWB 4x4 Collector
Re: 72 door panels
You will have to buy a used set of rings from a board member, eBay, or junkyard. Might have to buy a junk set of door panels for the trim. Trevor
TREVOR
Old 05-02-2015, 08:47 PM   #6
notsolo
notsolo's Avatar
Re: 72 door panels
Used Parts on parts board maybe WTB 72 door panel. trim.....I painted mine a lot of work and not as nice as original... Here SWB did a nice job DIY vinyl wood grain. http://67-72chevytrucks.com/vboard/s...d.php?t=660030
notsolo is offline   Reply With Quote
Old 05-02-2015, 08:58 PM   #7
lifeinak
Re: 72 door panels
Got it. Thanks again
Old 05-03-2015, 05:36 AM   #8
WIDESIDE72
WIDESIDE72's Avatar
Re: 72 door panels
I have a question relAted to the cheyenne door panels. I have a pair of custom deluxe door panels with the scroll pattern and stainless trim. I always thought that the stainless trim could be removed and the cheyenne wood trim installed in place. Is this true? I have a cheyenne but it had some "customized" panels installed by a previous owner. I ran across the dArk green panels I have in another cheyenne (without the woodgrain for some reason) and since they were pretty nice, repainted them black and installed them in my truck.
WIDESIDE72 is offline   Reply With Quote
Old 05-03-2015, 11:31 AM   #9
57taskforce
All about them K’s
57taskforce's Avatar
Re: 72 door panels
yup just remove the stainless trim, add the wood grain inserts, then reinstall the the trim. Be carefull not to break any of the tangs that hold the trim on.
Tyler
57taskforce is offline   Reply With Quote
