292 cam question.
Re: 292 cam question.
is that a crack at the base of the intake? or a stray hair?
Cracked or not cracked, a hair or not, it don't matter with that intake!!
It don't fit your 292!! It's for a 235!!! http://www.cliffordperformance.net/M...gory_Code=C235 |
Post Whore
![]() Join Date: Mar 2013
That intake will Not fit your 292. The round ports are for a 216,235,261. Heck that might even be for a GMC 302. But, you can get an offy intake for $289 and headers from Tom Langdon at Langdon Stovebolt.com for $189 I believe. A good cam would be something around 240-250 duration. 206 @ .050 .450 lift on a 110 lobe center. But you really would want to do some head work to. As it sits now...you have a torque monster made for torque at 2000 rpm. That head is low flow with small 1.72 intake and 1.50 exhaust valves. Smart thing to have done would be lump ports and a 1.94 intake valve. The same cam I mentioned above would work fine. Also have the head shaved .030 to help keep the compression up. Putting in a larger cam will lower your compression. A new 292 had 8.0.1 compression. You can get a new set of pistons from Summit racing for fairly cheap and they'll bump your compression to 9.5.1. I'd suggest a 4 barrel, 4 barrel offy intake, langdon headers, and an hei..backed by a nice 5 speed that'll make a noticeable difference in power. I have 3 of these engines and have experimented with them all. If you put in a new cam I'd do one like or similar to this one.
This cam is a 240H 192/ 200 @.050 .455 lift on a 108 lobe center. Good for a just above stock engine. http://www.compcams.com/Company/CC/c...x?csid=58&sb=2
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Ok so thanks for the input on the intake. Anyhow Seeing as I still am going to have to put a cam in regardless, I'd still like to have a few more options. Like I said I want a bit more performance. As much as I'd like to, I'm not about to pull the head and take it into a shop to rework the whole thing. It's just not in my budget. The cam I have now is ruined so I figure while I have it out I might as well put a "better" one in. Just can't seem to find one.
#6 | |
Post Whore
#7 | |
TJ - Are you sure that cam will work with a 292? The fuel pump eccentric is in the wrong place. I suppose it will fit but you'd need to use an electric fuel pump. Or maybe I am missing something?
...ned. Quote:
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
#8 | |
Post Whore
![]() Join Date: Feb 2002
I went with a Crane 260H cam. On the mild side, but lumpier than stock. Not sure if you can still get Crane cams, as they went out of business a couple years ago, but I heard they restructured.
With a new cam. you'll want new lifters, too. If you had a more recent, made-for-L-22 Series L6 intake, like Offy or Clifford, I would suggest the Edelbrock 1404 500 CFM 4 barrel. Don't feel bad. You're not alone. I have an obsolete ['60s?] Edelbrock SBC intake that's less a performance improvement than a later GM stock intake, and an Offenhauser BBC intake that has rectangular ports, unlike the small oval [or peanut?] ports on the 454 [c.'78] that was on my '67 K/10 Suburban. Each one I paid $50 for at swapmeets, only to find I couldn't use 'em. Hang it on your shop wall or ceiling as a trophy.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-07-2015 at 11:41 PM. |
![]() Join Date: Sep 2009
Love the the 6 have original 292 in my 66burb. had a 68 panel truck with a stock 250 and long tube headers and offy intake and 390 holley. ran really well
#11 | |
I ran the 390 Holley for 25 years, (with Clifford long tube headers and Offy intake) but after the 500 mile break-in on a rebuilt 292 it wouldn't ''settle down''. It was thought the Holley needed a new un-warped 4160 throttle plate base, and it was more cost efficient [and a great excuse] to throw on a 1404 Eddy instead.
Post Whore
Turboed 292's on 8 pounds of boost have made a good 400+ pound feet of torque. That's plenty considering people put boring 350's in those burbs your talking about and a 290/350 only has about 330 torque. I've said this ever so many times...Never take advice from V8 guys about 6 cylinders...all they're gonna say is the same thing over and over even though they haven't done it for themselves.
