Old 05-02-2015, 02:16 AM   #1
DustyNova
Dropping An old Oldsmobile 403 into a 1989 chevy blazer?
Could it be done? Its got a 700r4 tranny 4x4
DustyNova is offline   Reply With Quote
Old 05-02-2015, 07:14 AM   #2
kalbert
Re: Dropping An old Oldsmobile 403 into a 1989 chevy blazer?
Sure, but you'll need an adapter for the bell housing. I don't think there was ever a BOP 700r4 for you to swap tailshafts.
kalbert is offline   Reply With Quote
Old 05-02-2015, 10:47 AM   #3
andrewmp6
http://www.summitracing.com/parts/TCI-230001/
andrewmp6 is offline   Reply With Quote
Old 05-03-2015, 11:02 AM   #4
JMac11
JMac11's Avatar
350 Diesels in the 80's trucks were converted 350 Olds Gas motors.....
JMac11 is offline   Reply With Quote
Old 05-03-2015, 12:21 PM   #5
Titomars
Titomars's Avatar
actually out west here the default swap changing out the 350 diesels was the Olds 403. the 403 shared the same deck height as the diesel so even the exhaust bolted right up
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 05-03-2015, 08:31 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
Incorrect. 350 diesel blocks are completely different internally. Heads are completely different. Intake manifold is completely different.
That said, the exhaust manifolds and engine mounts will work with the 403. if you can find a 78-81 chevy truck that still has the diesel in it (good luck) everything you need for the swap will be there.
Old 05-03-2015, 10:31 PM   #7
Titomars
Titomars's Avatar
I think he meant swapped over to Olds 350 gas engines.
Old 05-03-2015, 10:47 PM   #8
DustyNova
believe it or not i actually see a few of the 6.2s round here in utah
Old 05-04-2015, 10:21 AM   #9
JMac11
JMac11's Avatar
Not to argue... but many 350 Deisels just had the heads and intake swapped to gas heads (Requires drilling out head bolts, as deisels had larger bolts) intake and distributor.... Presto, you have a gas burner. thick head gaskets helped knock down compression, gear to drive vacuum pump was same as distributor gear..... Lots of power, solid bottom end and roller cam
Old 05-04-2015, 05:18 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
A ton of them got swapped in central cal if they hadn't blow up 1st.
A some where resurrected with gas parts after they blew up.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
