Old 05-02-2015, 12:01 PM   #1
81GMCSierra1500
81GMCSierra1500's Avatar
Shaking over rough roads/bumps
Hey!
I'm just narrowing down on little issues (finally through all the major stuff, yay!) but one thing sticks out like a sore thumb... it shakes like a leaf over rough roads or bumps, it's not just like a front end wobble, the whole frame "wiggles" over rougher roads, it's mainly felt everywhere, except in the steering wheel... I've got a hunch it's something wrong with the rear suspension... Shocks? broken leaf spring? What are y'all's thoughts?
1981 Sierra Classic 1500, 305 4BBL, Ltd. Slip Rear End
81GMCSierra1500 is offline   Reply With Quote
Old 05-02-2015, 12:16 PM   #2
Cabnchassis
Re: Shaking over rough roads/bumps
Check all the cross-member connections. On my C&C I was getting some weird vibe and clatter, tranny cross-member had worked out both bolts on one side. Bushings in the leaf springs could just be completely gone too.
Look at the short fat leaf on the bottom of the stack, how well is it aligned with the other leaves? Do your shackles look ok?
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 05-02-2015, 12:27 PM   #3
81GMCSierra1500
Ill take a good close look in a bit. thanks a million for those tips! I'll let you know
