Old 05-02-2015, 04:19 PM   #1
jim-bob
6-studs v/s 5-studs
...why do most folks change over their original 6 bolt hubs (axle) to 5? Like on my 67 GMC..
jim-bob is offline   Reply With Quote
Old 05-02-2015, 05:11 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: 6-studs v/s 5-studs
Number one answer will be: Because there are 78 percent more wheel options for 5 on 5 wheels than there are 6 lug wheels.
You can buy 5 lug axles for your rear end (with a spider gear kit) but the front is more of a challenge unless you are doing a disc brake conversion. Then it is as easy as finding a 71/72 C10 pick up and swamping the complete cross member as they are disc brake with 5 on 5.
Hope this helps,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 05-02-2015, 05:14 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
More options for custom wheels and stock 71 and 72's had factory disc brakes (5 lug).
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-02-2015, 05:41 PM   #4
jim-bob
Hope this helps,
Tom
..I'm not sure i follow you, I'm sorta dense.. I do want disc brakes all way around but are you saying there's no conversion kit offered for the original 6 lug pattern...What do you mean "swamping the complete cross member"??
Old 05-02-2015, 05:59 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
There are many 6-lug disc brake kits.
CPP, McGaughy's, Early Classic Enterprises, Performance Online all have 6-lug kits.
The 67-72 trucks don't require a spider gear set to convert the rear axles to 5-lug.
And swapping used 71-72 or 73-87 crossmembers to get 5-lug rotors up front is a thing if the past!
All spindle manufacturers make direct bolt on spindles now.
No need to do a crossmember swap.
Keith
Convert to disc brakes.
Old 05-02-2015, 06:22 PM   #6
hugger6933
No need to swap unless your on budget restrains and/or have a bunch of truck parts laying around. Jim
hugger6933 is offline   Reply With Quote
Old 05-02-2015, 06:25 PM   #7
In The Ten Ring
I'd stick with the originals man.
In The Ten Ring is offline   Reply With Quote
Old 05-02-2015, 08:24 PM   #8
jim-bob
..you mean stay with the 6-lug?
Old 05-02-2015, 08:29 PM   #9
jim-bob
..thanks Keith..so staying with 6-lug will just limit my choices in buying wheels..Is there any other roadblocks?
Old 05-02-2015, 08:43 PM   #10
In The Ten Ring
You betcha! If you can get disc brakes that will work with the 6 lug, then why change? How custom to we have to be concerning rims anyway?
Old 05-02-2015, 08:54 PM   #11
lolife99
lolife99's Avatar
Just remember MOST 6-lug aftermarket wheels, made TODAY,... are for the 99-2015 silverado trucks.
Same bolt pattern,... but the center bore is way smaller than the 6-lug wheels built before 1971.
The hub on your 6-lug rearend is way bigger.
Personally I would switch to 5-lug.
It's a toss up on money.
Aftermarket 6-lug rotors vs aftermarket 5-lug axles.
Wheels selection will be greater in the 5-lug 5x5 pattern.
Keith
Old 05-02-2015, 10:59 PM   #12
TBONE1964
Cluster King
TBONE1964's Avatar
Not to argue Keith but it was my understanding that the 6 lug axles from 65-69 had a different spline count than the 70-72 axles which is why I thought you would need to change the spiders. I may be very well mis informed on that.
And yes there are certainly many options other than cross member swaps depending on a persons budget.
Good information,
Take care,
Tom
Old 05-03-2015, 04:34 AM   #13
lolife99
lolife99's Avatar
Only the 63-64 rearends require the spider gear swap along with new axles.
https://www.performanceonline.com/19...IDER-GEAR-SET/
http://67-72chevytrucks.com/vboard/s...d.php?t=603025
Keith
Old 05-03-2015, 08:13 AM   #14
jim-bob
..thanks to all..great info..believe I will change over..
