05-03-2015, 04:46 PM | #1 |
Wiper transmissions
Could anyone tell me the difference between 47-53 wiper transmissions & 54-55's? Thanks
yoshi's 49 project |
05-04-2015, 07:21 AM | #2 |
Re: Wiper transmissions
47-53 used a very short link for the driver side and a long for the passenger side. The 54-55 first linkage was almost equal in length on each side with a different wiper motor.
05-04-2015, 12:51 PM | #3 |
Ah I see, I have a 49 but I picked up a 54 wiper kit hoping to use it. I guess I need to either get the 54 transmissions & work with them or find someone who'll let me get a template or measurements from a 47-53
05-04-2015, 05:58 PM | #4 |
For a while I used a 62 electric motor in my 59. I just lengthed and shortened the arms to get them to work. IF you do not care about them not being stock some one could probably get you the measurements and configuration to modify what you have.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
05-05-2015, 04:56 AM | #5 |
Ok thanks, not too worried about originality. Some help with this would be much appreciated if anyone can, thanks
05-05-2015, 03:58 PM | #6 |
Looking at images they look to be straight, not bent like later models. Tricky part would be fabricating the ball socket end that mounts to the transmission end, you could adapt a mini-heim rod end. Wiper motor end is a hole for the grommet. maybe a AD guy here can supply center to center dimensions or you could use round rod and a threaded rod end.
05-05-2015, 05:37 PM | #7 |
I'm not positive but was the 54/5 wiper motor relocated more to the center of the truck than the 47/53 one was?
For show and tell only: https://www.chevsofthe40s.com/shop/s...T&Seach=Search Scroll down the page and there are photos of both styles of wiper transmissions.
05-06-2015, 11:47 AM | #8 |
Yeah I guess if both arms are the same length then it must be in the middle. Anyone got a 47-53 driver's side transmission arm? Thanks
