Old 05-03-2015, 06:42 PM   #1
davepl
davepl's Avatar
Why do we need so much darned initial static timing?
The BBC in my truck wants, according to the tuneup sticker, (I think) 4 degrees initial with an auto and maybe 0 degrees with a manual. But whatever the actual numbers, 4 is the ballpark. And it'll barely run like that.
Over the on Chevelle forums, where there's a bit more big block stuff going on, the consensus seems to be that most are finding 16 degrees initial is required for best idle, and you then wind up pulling out total so you don't overshoot.
If that's true, great. But as much as old timers complain about "today's fuel", I still don't really know the how and why of us now needing so much more advance. It's not like nitro (very slow burning)!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-03-2015, 09:19 PM   #2
kwmech
Re: Why do we need so much darned initial static timing?
I've got the big block in my 68 set up with an initial of 4btc. Runs great, does not ping. My small block 400 in my 69 flat bed is set at 6btc and runs as well as the BB, plenty of power and no pinging. If I take the timing up in either truck........pings like hell and does not want to start after it warms up, I get that hard starter spin
Old 05-04-2015, 04:33 AM   #3
donut
donut's Avatar
More initial can give you better throttle response, if your truck tolerates it.
Chevy specs, IMO, were to get the customer through the warranty period and pass emissions.
My smallblock liked 14-16, BB 16-18. In my case, I would get starter backlash before it would ping. (running 87 octane)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-04-2015, 11:46 AM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
My BBC took 18 to idle cleanly with good throttle response. I have a Performance Distributors 'D.U.I.' distributor that they custom curved for me. They recommended 12* initial as a baseline and to go from there. I know that doesn't tell you the 'why' but it is what it is.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-04-2015, 12:19 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
The 'why' is more about the 'RATE OF BURN' in milliseconds and the expanding gasses exerting pressure on the piston for xx° after TDC. (low speed torque and throttle response) and the RATE OF COMPRESSION and the Max PSI of the fuel mix before it detonates.
There is a LOT of flys in the ointment tho...
like,
As RPM's increase you have to initiate the burn earlier, to have the gasses put as much USABLE pressure on the piston, for as many crank degrees possible. As the piston races away from TDC, it will make the effect of the expanding gasses 'less effective'.
Just for example lets say gasoline will take 10milliseconds to do a 80% burn at 150PSI.
And lets say it takes 20 milliseconds for the crank to sweep 90 degrees at 1000rpm
All very dependant on stroke and rod length it may only take 5milliseconds to sweep 90 degrees at 6000rpm. We better start the burn EARLIER to have the best use of the fuel.
Then too it may take WAY longer in a dished piston, large chamber low compression motor to complete a 80% burn, than it will a 12:1 motor.
Not that there is NO pressure after xx°, just that it is not enough to create any really usable torque. i.e the exhaust valve opens on a Comp 284H at 100° (crank degrees) ater TDC,, the pressure is so negligible all it's good for is making a sonic boom in the exhaust pipe,, not any real 'torque'.
The whole 'rate of burn' and how it is effected by compression, and the RATE of COMPRESSION is the science custom cam grinders deal with. If I know all that I'd be selling you cams LOL
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-04-2015, 01:21 PM   #6
snj8198
snj8198's Avatar
milliseconds? sweep? The? Let's say I get another cup of coffee
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 05-04-2015, 01:29 PM   #7
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Set the timing to how the engine runs best and call it good. Factory specs are going to be right for some engines and wrong for others because no engine is built Exactly the same. Some engines might like 8 degrees advanced while others may like 16 degrees advanced. Time it to how it performs the best and call it good, but don't advance it to far or you risk detonation.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-04-2015, 04:45 PM   #8
RIDE-RED 350r
RIDE-RED 350r's Avatar
Funny you bring this up...
My truck has a 350 in it. All of the following were installed by the PO.
-Full length headers and 2.5" true duals
-Edelbrock intake
-Edelbrock 1406 carb
-"Mild" cam claimed by PO but I have not confirmed.
-Some sort of fancy red distributor
I was doing some maintenance a couple of weeks ago and found my base timing at 16 deg.
This engine shows the outward signs of an out-of-chassis rebuild not too long ago.
I have had the truck a little over a year and it runs great. Low end seems pretty strong but it seems to really pull best between 2,000 and 3,000. Guess that can be attributed to the smaller CFM carb?? One thing I have learned though, it does prefer 89 octane fuel over 87. With 87 it would spark knock a little bit if I lugged it under 1200 rpm in 4th gear.
I was wondering if I should back the timing down, but I talked to a fellow who is very knowledgeable with this stuff who told me that much timing is pretty common for the way my engine is set up.. So I left it as-is and run 89oct in it.
Who needs a Hemi when ya got a Chevy!
RIDE-RED 350r is offline   Reply With Quote
Old 05-04-2015, 08:02 PM   #9
b454rat
Bulb blew in the timing light years ago, never needed it. I set it close, drive it and see how it does. Advance it till it pings, back it off. Hard hot start, same thing. My f'n malibu has a 454, 10:1, iron heads and runs 93. Starts just as easy hot as cold. Doesn't ping, instant throttle, (too much and your sideways) so I'd say it's pretty good.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 05-04-2015, 08:59 PM   #10
Hollow65
Hollow65's Avatar
I've never done anything less than 12. I start with 12* and tune from there. I'm currently at 16 initial and 36 all in. Chevelle tech is a great site. Lots of smarts over there also. Ddennis, is super knowledgable.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 05-04-2015, 11:01 PM   #11
cableguy0
Scratch the factory sticker off of the core support. That sticker is there for emissions purposes. No engine runs best at the factory settings. If it did hot rodding wouldn't exist. The first thing guys did in the old days was reset the timing,recurve the distributor and rejet the carburetor. 16 isn't ridiculous on advance by any stretch.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-04-2015, 11:33 PM   #12
crazy longhorn
Fabricate till you "puke"
Forget about the initial...set the total @ around 36 degrees, @ 2800-3200....where does the initial fall? Add 8-10 degrees to the vac can (at the crank)_, & you should be damn close I agree with Marv....after a couple more glasses of bourbon, we would have fun conversation! Honestly, that mill will be running/ pulling max mechanical advance @ 3000 rpms.....on a lite throttle "cruise', you may see 46-50 degrees, with the vac can involved? Figure , that most HEI dist, have about 20 degrees in the mechanical advance....I would add 14 to 16 intial to that. He!! we run 18/38 on the track in little bros truck...no vac advance, cut @ 2600 Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-05-2015, 12:08 AM   #13
Marv D
Marv D's Avatar
Yeah I guess I read too much into Dave saying he was curious of he How and Why of needing significant advance to make our 40 year old motors happy. I do that sometimes LOL
CL would love to have that conversation some time
Old 05-05-2015, 12:27 AM   #14
crazy longhorn
We will kick er, back/forth, one nite when my head is a little more clear! Trust me, you have raced for many yrs...I trust you, & will bet that I can learn a bunch from you longhorn
Old 05-05-2015, 08:15 PM   #15
Hollow65
Hollow65's Avatar
Do you have a vacuum guage? And vac advance?
