Old 05-03-2015, 07:07 PM   #1
S10pro
Help fitting newer gm 6 lug wheels on 67-70 c10?
Has any one bored out center Hub hole to run newer style 6 lug Denali or escalade wheels on our truck s please post info thanks
S10pro is offline   Reply With Quote
Old 05-03-2015, 08:13 PM   #2
dirtyjim
dirtyjim's Avatar
Re: Help fitting newer gm 6 lug wheels on 67-70 c10?
because of the offset you would be better off running spacers. bora can do the spacers with bore on the back side for the 63-70 hub and later hub ring on the outside of the spacer.
a better ay would be to convert to disc up front and run cpp 6 lug rotors, they already have the smaller hub size then on the back either run spacers or have the axle turned at a machine shop to fit the later model wheel bore.
the wheel hubs can and have been machined, I think some people have also used a ball bearing step bit in a router to open up the bore on aluminum wheels making them lug centric
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 05-03-2015, 09:20 PM   #3
hugger6933
I have seen so many of those type wheels on our 67-72 trucks it can't be that hard of a thing to do. I've seen both steel and all sorts of the alloy wheels. I have a set of the Suburban/Tahoe wheels that came in on one I've junked planning to use them, So I too am needing the info on what it takes.
hugger6933 is offline   Reply With Quote
