05-03-2015, 09:12 PM | #1 |
Climate A/C-Heat Control Head Unit 2006 Chevy 2500HD
Have a control that does not heat on passenger's side. Need to repair or replace. Does anyone know of a repair shop that services these units? or a good used replacement?
Fits 03-09 Chevrolet Trailblazer 05-06 GMC Sierra 2003-2006 CHEVROLET SILVERADO 2500 May fit other models not sure of all. Thanks |
05-03-2015, 10:40 PM | #2 |
Re: Climate A/C-Heat Control Head Unit 2006 Chevy 2500HD
welcome aboard! i'm assuming it is the little actuator motor you are needing, if so look to see if the 2 halves come apart. Possible cleaning up the inside brushes will take care of this. If it's the control head i just say a repair place called "speedometer repair guy" located in winona minnesota that does hvac repair. If you get stuck, pm me when i have more time and can check further into this, i'm friends with the local gmc dealer and have access to alldata pro. Good luck, Brian F.
