Old 05-04-2015, 12:35 AM   #1
mw67rs
Convert TH350 from 2wd to 4wd?
I have a rebuilt TH350 for a 2wd and was planning to put it in my 4wd. I noticed the output shaft is longer on the 2wd. I did some searching on Youtube on how to disassemble a TH350. It looks like you need to remove all the guts for the transmission to get the output shaft out. Looks a little intimidating but not impossible. Anyone ever swapped a 2wd output shaft for a 4wd in a TH350.
I am fairly mechanical and have rebuilt engines but never a transmission. Is this something I should try or leave it to the professionals? I thought I could pull the only TH350 that was in the truck apart to get the output shaft out of it and if it looked like something I could put back together then give it a try on the rebuilt one. What do you all think?
Can anyone recommend any good videos or books if I do decide to give this a try?
mw67rs is offline   Reply With Quote
Old 05-04-2015, 02:27 AM   #2
andrewmp6
Re: Convert TH350 from 2wd to 4wd?
If it was me i would let a trans shop do it and while they are at it rebuild it so its new and ready to roll.But any reason you want to keep the turbo 350 and not upgrade to a turbo 400 or run a 700r4 and get a overdrive gear?
andrewmp6 is offline   Reply With Quote
Old 05-04-2015, 04:22 AM   #3
donut
donut's Avatar
When I needed a transmission for my K-20, they took a standard 2wd trans and made it for a 4wd. (I had a shop do it)
Output shaft has to be changed and the tailshaft lost. Your transfer case will bolt to where the tailshaft was. Entire trans has to be gutted, so rebuild it while you got it apart.
@andrewmp6, the output shaft is different between the 350 and 400. If you get beyond that, the driveshafts will have to be re-worked as the 350 and 400 are different lengths. When mine was done, I had a 4wd 400 in the shed. IMO, lot less work to get the 350 rebuilt.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 05-04-2015, 09:22 AM   #4
jjzepplin
jjzepplin's Avatar
Yup and you will need a different transfer case for the t400 as well.
I have a short t350 shaft for you.
I did my 700r4 and I used a video. Turned out fantastic and that was a long time ago.
I have this shaft left over from a build I was gonna do but went 2wd instead.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
