head light knob removal
Ok,,,,I'm taking the bezel with all the gauges in it out of the dash on a '69 chevy short bed,,,,how do you get the knob for the headlight switch off. Looks like the knob for the window wipers has already been replaced with one thats got a set screw in it. Might I have to do the same thing with the headlight knob? Thanks,,,Bill
Re: head light knob removal
1. Pull the knob all the way out (headlight on position).
2. Reach up to the switch behind the dash. 3. Locate the small button/plunger on top of switch. 4. Press button/plunger. 5. Pull the knob shaft out. Don't forget to put the shaft/knob back in to turn your lights off.
'72 Blazer, A/C, tach, tilt. Not on the road at this time '87 v30 Custom Deluxe, standard cab, SRW, Utility bed '86 c10 Silverado longbed (for now) '19 ecsb, 2500, 4x4 '15 Subaru Legacy - commuter |
Thanks for the info,,,,I"ll hunt for it,,,,LOL,,,redoing the dash,,,airbrushing it,,,,
The Older Generation
You will have better luck if you only pull the knob out to the park light position before you push the spring loaded button in.... Here is a picture of it. (not my pic) LockDoc
![]() Join Date: May 2003
Learned something new today..... Never knew about the spring loaded button !
Who said you can't teach an old dog new tricks ???
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Someone ought to chime in, since the wiper knob is probably also going to have to come off: There's a set screw on the wiper knob. Flathead, small screw that will let the knob for the wipers pull off.
Jeeeez,,,,thanks for all the replys,,,the pic helps too,,,,,
