Old 05-04-2015, 12:01 PM   #1
droy014
Help identify motor
When I Bought my 68 I was told it had a 350 in it. I pulled the engine yesterday and started looking at the numbers on the block and was wondering if you guys could help to identify it. Casting #3970010 Date code J0377 and ID number on the front pad is MK21289. From what I can find the 3970010 could be a 350 or 327. Also I found something that says the MK on the ID number is a 327 built in 1967. The block was made in Mexico if that helps. If anyone could help I would very much appreciate it.
droy014 is offline   Reply With Quote
Old 05-04-2015, 05:18 PM   #2
bruceman1968
bruceman1968's Avatar
Re: Help identify motor
Hi Droy014, Welcome to the board. Your block is a 1977, 350, crate manufactured in Mexico
J0377
J=October
03= 3rd day
77=1977
MK21289
MK=I don't have a decode for crates, but that is a Mexico prefix
21289=part number
3970010=in 1977 that's a 350
Hope that helps
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 05-04-2015, 06:50 PM   #3
leftybass209
leftybass209's Avatar
Bruceman is right on. To add a little disappointment perhaps. There is no way to figure out the rated hp/tq for a crate. The best you can do is remove the cam and inspect it for a part number. However, the cam is the only component separating a 260 or 290hp 350, and once it's out its too easy to swap in anything you want.
leftybass209 is offline   Reply With Quote
Old 05-04-2015, 10:08 PM   #4
droy014
Just want to say thank you to you guys that gave me the info I was looking for.
