how many ohms do i need
I am running with the original gas tank behind the seat. I am running all new gauges not the stock cluster but the sending unit I got is for the tank mounted under the bed
should I try to find a sending unit to run the new gauge with the stand up tank or maybe a new gauge that runs same ohms as the stock sending unit I have ??? no computers I have a 350 chevy with a holly 660 and 700R4 any advice would be appreciated |
Re: how many ohms do i need
Factory was 0-30. Most of the newer stuff is 0-90. I'd check the sending unit and see if it lends any info. The back of the gauge should have it listed also.
I'm not sure if you can use the bed sending unit in the in cab tank though just due to the design in how the tank "stands up" vs. lays down for the bed style tank.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#3 | |
i have the 90 ohm gauge and a 30 ohm sending unit because of my old style inside gas tank question is can i find a 90 ohm sending unit for my tank or can i modify mine? or can i find a 30 ohm new style gauge |
I'm unsure of that. I'd have this moved to the electric section. Would probably open up more answers for you.
PM the mods.....they can move it for you.
a pic of my truck not that it matters
Great looking truck!!!
#9 | |
It's Better With Nitro
Just in case you want to go this route for your gauge/sending unit interface...http://67-72chevytrucks.com/vboard/s...d.php?t=288717
