Old 09-01-2003, 09:23 AM   #1
Chevelle454
Chevelle454's Avatar
383 Stroker Q's...
How much time and work is it to make my 350 into a 383 stroker? I know that you need a 400 crank, flywheel and balancer, and rods. What else is there? And how much would this end up costing me?
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 09-01-2003, 09:39 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Check out the Jeg's and PAW cataloges.They should be online.Then get with your machine shop and check their pricing.This will give you a ballpark figure.i USUALLY ADD ABOUT 10 TO 25% to that.
I would also encourage you to look at Scoggins-Dickey or some of the other GM genuine performance parts websites,since Chevy now offers a 383 crate motor which should be available as a shortblock by now.It may be $$$wise to do that since it would have a warranty.
Good luck and have fun!!!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-01-2003, 09:45 AM   #3
bigjimzlll
bigjimzlll's Avatar
you will need new pistons and have the assembly balanced. The machine work cost me 600 bucks..about 250 more than a normal 350
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-01-2003, 10:55 AM   #4
Chevelle454
OK...
I have a class in school for three hours every day for the first semester. This is where I plan to do the work.
I don't know a whole lot about car and truck engines. The biggest thing I have ever rebuilt is my Honda XR200(4 stroke) dirtbike. That had a siezed connecting rod, so I had to take the engine down to nothing and get the crankshaft in pieces. I got it all back together successfully and it runs perfect.
I don't think it could be too hard to rebuild just an engine with no transmission to try to work with(like the dirtbike). Plus I have you guys here to help me out if I run into any trouble with the engine.
I love this board!
1972 C10
1972 C20
Old 09-01-2003, 11:25 AM   #5
miket
miket's Avatar
Chevelle.
It is a great board and I would suggest any of the major parts houses for parts or Sallee Chevrolet for a complete crate 383.....there are also several good books to work with as well which I am sure can be found at Amazon.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 09-01-2003, 11:31 AM   #6
Dean23
68cst_ss490
Dean23's Avatar
heres a stroker for you....
http://www.xtremeengines.com/html/en.../chevy383.html
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 09-01-2003, 12:10 PM   #7
Chevelle454
Well, I cannot buy a shortblock or a crate motor. I don't have 3 or 4 grand laying around. I need to build this motor with $1000 or less.
1972 C10
1972 C20
Old 09-01-2003, 12:11 PM   #8
Chevelle454
BTW, I already have a 350. I just need the parts to make it a 383.
1972 C10
1972 C20
Old 09-01-2003, 04:25 PM   #9
bigjimzlll
bigjimzlll's Avatar
you can get a budget stroker kit for 600 bucks..then the balancing//150...el cheapo machine work..300
Anderson,CA
Old 09-01-2003, 04:33 PM   #10
lewi
lewi's Avatar
big jim, I see you help on alot of engine related threads. I am here in you area and would like the 383 stroker, what would you suggest for a mid range budget on a truck that is used mostly weekends for fun and towing. Sorry guys (gals) if its off topic but I have been wanting Jim's opinion
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
Old 09-01-2003, 05:13 PM   #11
bigjimzlll
bigjimzlll's Avatar
why dont you give me a call...945 8975...we'll talk
Anderson,CA
Old 09-01-2003, 05:25 PM   #12
crazy longhorn
Fabricate till you "puke"
You can do a budget stroker, but be aware that many of the budget kits use a 400 sb "short rod" , & a 350 piston (5.565 vs the 5.7 350 rod). These kits will assemble, & USUALLY need no clearancing for the rotating assy.......the bad thing is that you may end up decking the snot out of the block ,to get the proper quench. I talked with 1 guy at a machine shop, & he had cut .050 from the decks of the block on 1 to get the quench in line. the shorter rod is in theory supposed to give a little more low end tork.....but most guys claim that the "difference " is eaten up by the extra friction......probably a good call too. My 383 was set up with 5.7 rods, & there is some rod & block clearancing involved.....also 3 spots on the oil pan were heated & clearanced with a ballpeen(for rod clearance). A "hotrod stroker " is not cheap to build, & If i do another one, it will be a 6" rod combo, with an internally balanced crank .....every time you swap a flywheel or balancer, you have potential problems with external balance. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
