70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Help with door
The passenger door on my truck locks and unlocks as it should opens from the outside but not the inside and the button goes up and down. I bought the truck this way. The rod was bent so I got one at the wreckers. The triangle part that the inside door handle attaches to works as it should. With the triangle piece unhooked the latch will not budge with rod. Is my door latch shot ? if jt is can I just undo the 3 screws that are on the outside of it and remove it that way?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Help with door
Are you saying that when you lift the inside door handle the door will not unlock? I didn't think they were suppose too, i could be wrong but i have never locked myself inside.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Help with door
No, what I'm saying is I can't open the door from inside the truck but can from the outside.
