05-04-2015, 08:27 PM | #1 |
Climate Control Question
I noticed that my Climate Control fan on my '74 is always running... It has a Low-Med-High fan setting, and apparently no way to have the fan completely off. Is this how these trucks were designed or am I missing something?
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
05-04-2015, 09:34 PM | #2 |
Re: Climate Control Question
That's how they are designed. It was called Flow Through Ventilation. In my opinion one of GM's more idiotic ideas.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
05-04-2015, 10:01 PM | #3 |
Some of the later ones have an off position on the blend door lever that will block the outside airflow and shut the fan off. Not sure when that started.
05-05-2015, 06:34 AM | #4 |
Mine in my 82 doesn't run unless I have the A/C or heat on...
05-05-2015, 06:53 AM | #5 |
Also I think it was designed to keep some ventilation in the vehicle in case there was carbon monoxide in the cab while it was closed up and sitting still . There was a lot of vehicles that did this for that purpose . Not just trucks .
05-05-2015, 09:52 AM | #6 |
I don't know about that. But I do know GM was the only manufacturer to do this and it was on all domestic GM light trucks and cars in the 70's.
05-05-2015, 10:42 AM | #7 |
78K & 79C Jimmys
yup it was the same with no AC.
I cut the low speed bypass(brown wire) @ the switch. my 78 has 3 speed,79 4 speed,both now have the lowest as an off position. I have a spare 79 I was going to see if it could wire up to the 78,to give me back the low.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
05-05-2015, 02:14 PM | #8 |
My 77 is low-med-high, no AC. It's a quirky switch because it spends all winter on high, and all summer on low.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
05-05-2015, 02:32 PM | #9 |
With a tiny push button switch and a relay you could make it be permanently off or on. There is more than enough space on the face to do this.
05-05-2015, 03:27 PM | #10 |
Why not just use a blower switch for an 82 up. The same cab, there can't be too much different in the controls. This is actually what i am going to look into.
05-05-2015, 04:01 PM | #11 | |
By putting a small push button switch together you could have your off/low/med/high |
05-05-2015, 04:34 PM | #12 |
78K & 79C Jimmys
my 79 can give me "off" and three speeds for the the 78,
prob just switch the wires over in the plug,and the controller Note the resister coils are different,doubt that matters.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 05-05-2015 at 04:44 PM. |
05-05-2015, 04:36 PM | #13 |
my 82 has a 4 position fan switch, the fan is turned on by selecting ac/heat/defrost and is turned off by selecting the off position
05-05-2015, 07:33 PM | #14 | |
I wonder if I moved the Heat-Defrost lever to OFF if that would affect the fan. I will take a stab at it and see what happens.
05-05-2015, 07:38 PM | #15 |
