Old 05-05-2015, 02:16 AM   #1
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
At first i thought i'd lost a wheel..........
On my way to work on the 1st of May, I had to stop at a 4 way intersection in a not too particularly safe part of town less than 5 blocks from work.
As I lifted my foot off the whoa pedal and started to press on the go pedal, the rear end started to buck and shake..... then... the right rear dropped... with a very hard THUNK!!!
I had been brought to a dead stop in the middle of the intersection. I got out to see what the frack happened and saw this.......
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 05-05-2015, 02:21 AM   #2
BLE 'BURBAN
Re: At first i thought i'd lost a wheel..........
Needless to say what had happened is during the winter the rear end developed a leak and the right rear wheel bearing finally seized up on me and snapped the axle. So it now sits with the rear end on a jack stand looking like something old man Howard Stark was trying to create....
Old 05-05-2015, 02:29 AM   #3
BLE 'BURBAN
I hadn't noticed the leak because I go to work in the dark and come home in the dark and never noticed the oil puddles until way, way, way, too late.
And I never walked around the right rear of my ride before then either. It bent the hell outa my disc brake conversion caliper mount and snapped the caliper mount bolts clean off. the only thing keeping the wheel attached to the truck was the braided steel brake hose.
Old 05-05-2015, 06:56 AM   #4
walkerb
walkerb's Avatar
Wow, good thing no one was hurt. That's a good SS brake line!hahahah What's the plan, swap axle or the whole housing?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 05-05-2015, 09:02 AM   #5
greg64
greg64's Avatar
Woah! Good thing that broke at walking speed.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 05-05-2015, 09:07 AM   #6
J Knight
J Knight's Avatar
I saw a vid a couple of days ago where a burb on the interstate lost a rear wheel...it did a couple of 360's, tapped a car then hit the wall. You got lucky.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-05-2015, 10:04 AM   #7
BLE 'BURBAN
It bent the lip of the tube at the top so yeah, I'm gonna have to replace the whole assembly.
Old 05-05-2015, 10:09 AM   #8
BLE 'BURBAN
Considering I was just on the highway not 5 minutes before this doing almost 70.... I'd have to say I had a co-pilot of biblical proportions with me that day.
Old 05-05-2015, 10:29 AM   #9
rustyescott
rustyescott's Avatar
need more info on disk brake swap
rustyescott is offline   Reply With Quote
Old 05-05-2015, 10:37 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
WOW you said it!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
