Old 09-01-2003, 10:27 AM   #1
Beowolf
Lifting without Blocks
I'm buying new springs for our 71 4x4 truck. We are planning a 2 1/2" lift. What option do I have besides using lift blocks for the rear end? It seems that it would be a better setup to have the springs mounted right to the housing. All the kits I found only had the blocks - no one seemed to have new rear springs to match the front lift. Thanks.
Mark
72 Blazer CST
71 1/2 Ton 4x4
Beowolf is offline   Reply With Quote
Old 09-01-2003, 01:57 PM   #2
sakohntr
sakohntr's Avatar
ORD
Off Road Design makes a rear spring shackle kit to add height. While your at it get there front greasable shackles as well.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 09-01-2003, 02:42 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Tuff Country, also available from Off Road Design sells rear springs as do a few of the other companies. Most of the kits you see are just blocks for money savings, but you can usually upgrade to rear springs. I'm using the shackle flip sakohntr mentioned. It is nice as you retain your stock springs.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-01-2003, 10:03 PM   #4
Mike C
Mike C's Avatar
Note that the ORD shackle flip is a 4" lift. I have a 4" on the JImmy with Rancho fronts and National Drivetrain 4" HD leafs in the rear. Mega stiff, but I thought necessary for trailering I do.
I would go with a Skyjacker 2 1/2" kit with front and rear springs, but there are other kits out there as noted.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-03-2003, 12:29 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
ORD does have the shackle flip for a 2 1/2" lift.
Old 09-03-2003, 05:01 PM   #6
714x4
I bought my 2 1/2 in. lift springs (front and rear) from Rancho about 10 years ago.
714x4 is offline   Reply With Quote
Old 09-03-2003, 07:43 PM   #7
Beowolf
A lot of good options. I don't want to go too high, but I like the short shakle flip idea. What drawbacks are there if I go with them? ( I am planning on using 3/4 ton springs to gain capacity.)
72 Blazer CST
71 1/2 Ton 4x4
Old 09-03-2003, 10:19 PM   #8
Richard
One drawback would be that the 2 1/2" version is only made for the 73 up trucks
I wanted to note after my snide remark that you could probably just flip the existing hanger and that should net about 2" of lift, will drop the end about 4". Drill out the rivits and bolt it on upside down.
I am doing that and moving the hanger back on the frame along with moving the front hanger forward, with the curve on the frame should net me about 3" of lift with the same arch springs.
Richard
Old 09-04-2003, 05:12 AM   #9
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Keep the stock springs and add a "long" add-a-leaf and that will stiffen them up a bit to get you a slightly larger capacity. Make sure it's a long one and not a short one that goes at the bottom(above the over-load) of the spring pack.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-04-2003, 05:11 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Dang, hadn't notice the shackle wasn't available in 2 1/2" for our year. Guess that gives you a good reason to go 4".
Old 09-05-2003, 10:53 AM   #11
72beast
TONYP
72beast's Avatar
I used a set of these to add 1"...so they would get you half way there...there called Zero Rates...
72 K/5
350/205
SOFT-TOP
DOUG THORLEY HEADERS
A/C
CUSTOM REAR BUMPER
http://www.socalbigdawgs.com/tr/7.18.03/DSC04290.JPG
72beast is offline   Reply With Quote
