Old 05-05-2015, 08:33 AM   #1
MikeB
MikeB's Avatar
fuel pump with two nipples
An AC-Delco #41216 fuel pump for a 1982 C10 with 350 engine has two hose nipples. What is the smaller one for?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-05-2015, 08:58 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: fuel pump with two nipples
Return line.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-05-2015, 10:53 AM   #3
MikeB
MikeB's Avatar
Originally Posted by hatzie View Post
Return line.
Interesting. How does it work vs. a pump with no return line?
There are no lines other than a 3/8" fuel line that terminate on the passenger side of the engine, The second hard line from the fuel tank (5/16") terminates at the evap canister on the driver's side.
The truck originally had a 250 six, so I guess I need to dig through the 82 shop manual to see how 250 and 350 fuel lines and evap canister connections differ.
Mike
Old 05-05-2015, 11:50 AM   #4
MikeB
MikeB's Avatar
OK, I see where the fuel return line is used to reduce chances of vapor lock. Not all 82 engines used it.
But all engines did use a line from the fuel tank to the evap canister. Guess they may have been a third line on some trucks.
Mike
Old 05-05-2015, 12:44 PM   #5
enaberif
Return line.
There is no return on the dual nipple.
One nipple is the feed line from the tank and the other line runs to the carb. The fuel can flow backwards but its not a return line.
enaberif is offline   Reply With Quote
Old 05-05-2015, 07:03 PM   #6
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Then how do you explain the outlet port right next to the other two nipples? It's got 3 ports... one of them has to be something other than the tank feed and carb feed.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 05-05-2015, 08:28 PM   #7
enaberif
The question was a bit misleading.. I apologize.. here is a diagram to help explain.
Old 05-05-2015, 08:55 PM   #8
Titomars
Titomars's Avatar
It is a 3 port pump. The outlet to the carb is for a hard line (threaded)
3/8th nipple is the inlet
5/16th is the return port to the tank.
not all trucks had the 3rd port. six's did not come with them. all 454's did. the SBCs it was based on certain engine codes
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 05-05-2015, 10:39 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
In my Jimmys the 78K -305 is two line no charcoal can.
Both 79s 305C and 350K have the third line and a can.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-04-2015, 10:45 AM   #10
MikeB
MikeB's Avatar
FYI, I traded in my pump for one without the return line. The new one is for use in various vehicles from 69 to 79, and has a 3/8" hose nipple and 3/8" inverted flare outlet fitting (5/8"-18 threads). So I'm good to go and don't have to worry about a rubber cap cracking.
Mine's the O'Reilly Auto parts "Precision" brand, but appears to be identical to Carter #M4685 that Summit Racing sells for only $13. Think I might buy a spare at that price. I've spent almost as much on a margarita!
Mike
Old 10-05-2015, 04:07 PM   #11
piecesparts
Parts and more parts
piecesparts's Avatar
Nope, that ain't it. The picture has two nipples and also a threaded fitting. The larger nipple is the feed from the tank, the smaller is the return to the tank and the threaded fitting goes to the carburetor. The smaller nipple is ported, so that a small percentage of fuel is returned to keep the fuel pump cooled, when the carb is not demanding a large amount of fuel.
Frank
piecesparts is offline   Reply With Quote
Old 10-06-2015, 09:53 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
This?
the two line was for the 78
3 is 79,tank is too
John
