09-01-2003, 10:40 AM | #1 |
71 - 5 bolt wheels
Hey guys I am switching my drum brakes for discs , Now i'n gonna need new rims , my discs came off a 71 c-10 , Does anyone know if the 5 bolt 71 rims are the same as 73 and up 5x5 bolt pattern? Most rims I see are for 5 on 5 bolt 73 and up. Thanks Tony
09-01-2003, 11:13 AM | #2 |
The 73^ 5x5 wheels will fit your setup. They may not look the same as the older rims, (not sure on this) but if they are the 5 on 5 pattern, They will fit.
Hope this helps! '71
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
09-01-2003, 11:21 AM | #3 |
5 bolt
Thanks, I just was not sure about that ! Being a carpenter I took out my trusty tape measure and measured the bolts from center to center and it measured 4.75" with a 3 1/8" center hub but I guess things are different in the world of mechanic's, thanks
