Limited Slip Differential.
Anyone have thoughts on using a factory Posi in a 7.5 28 spline rear end compared to an aftermarket Posi or Tru-Trac?
Re: Limited Slip Differential.
Yes I have thoughts. Stock late model "posi units" are anything but. They use a weight system to lock the side gears. around here they are called "whizbangs". The design allows for one tire to lose traction and start spinning. Thats where the weight system comes into play. the shaft the weights are on starts spinning and then engages the locking parts. so after this when the lock engages it shocks the other tire and in my experience it usually starts to spin too. I would hold out for an aftermarket plate type posi. I grabbed the image off of ebay
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
