![]() Join Date: May 2014
Power steering Hoses, What you running?
Just converted to power steering and was going through the FAQ and didn't really notice any specific reccomendations for Hoses to use.
Just curious if any of you out there have a specific one that works well. I was figuring the 73-87 ones must be close, but the clip I got to use did not have hoses with it so I have nothing to go by. Thanks in advance! ~Aaron
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
Re: Power steering Hoses, What you running?
I guess I should specify SBC power! low drivers side pump mount.
I never found any off-the-shelf hoses that would work. The return line isn't under pressure, so I made one out of 3/8" rubber hose and some hose clamps. The pressure line I fabricated out of AN fittings and steel braided hose. It's been working fine for two years, and my truck is a daily driver.
![]() Join Date: Sep 2006
I used stock hoses.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
If your small block has a short water pump and the correct power steering pump with a pre '80 steering box, you should be able to use a pressure hose for a '68-'72. If you have a long water pump with the correct power steering pump and a pre '80 box you should be able to use a '73-'79 pressure hose. If you have a long water pump and the Metric steering box, you would want a '80-'87 pressure hose.
For the return hose, be sure to use power steering fluid compatible hose. Regular fuel hose will breakdown.
Never Ending Projects
When I did my first C10 PS swap, I used the pressure side hose from a '68-'72 model. Worked perfectly. For the return, I got some generic 90* pump and box hard line fittings and use power steering hose to connect them.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Edelmann #70917 worked for me.
That is the pressure line. For the return line I got a pre-made brake line and bent it to exit the wheel well and once inside engine bay switched to hose. |
thanks for the heads up on the 73-80 hose Captain, that worked great. and yea im gonna make my own return.
