Old 05-05-2015, 05:55 PM   #1
kingstrider
kingstrider's Avatar
Best way to fix my rusty bed?
Well I knew there was some rust in my bed around the tailgate but finally got around to pulling the plastic bedliner out to see what it was hiding. I'm guessing the bedliner was in there a long time which allowed water to collect around the tailgate and along the edges, otherwise the bed looks fairly solid and has what I think is the original paint. I'm thinking of either getting some patch panels from another bed or just replacing the whole floor if I can find a decent replacement. My biggest concern though is the flanges along the left inner wheel well and the right fender where they bolt to the bed. Does anyone have suggestions on how to fix these areas using the original sheet metal? I can replace the wheel wells if needed but want to keep the fenders. I'm thinking maybe I can weld in some L-channel and blend that in where needed but if there's a better way I'm all ears.
kingstrider is offline   Reply With Quote
Old 05-05-2015, 06:01 PM   #2
WarMonger
WarMonger's Avatar
Re: Best way to fix my rusty bed?
Maybe order a re-pop floor. bolt your bed to it and do a spray liner?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 05-05-2015, 06:58 PM   #3
65standard
65standard's Avatar
Someone sells floor patch material. Maybe classic parts
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 05-05-2015, 07:40 PM   #4
In The Ten Ring
My dad made his own bed out of 1/8 inch steel plate. He was quite the welder then and welded it perfectly to 3 more pieces on the sides. It holds water perfectly and is plug welded to 4 bolts on the frame. It can be removed by one person and four jacks.
He probably got the steel for free from where he worked.......you may be able to do something similar.
In The Ten Ring is offline   Reply With Quote
