Old 05-05-2015, 07:03 PM   #1
87Chevy3853
hauling a UTV in a half ton
Hey everyone. I tried searching before posting but couldnt find an answer. I have a 87 silverado half ton with an 8ft bed. I bought a new rzr 570 and use my dads truck which is a 3/4 with a 6ft bed to bring it home. I dont want to bother him every time I need it taken in for service or when I go camping. The rzr weights 1000 pounds. Regardless of my vehicle being overweight since this maybe used as a hauler 3 times a year ill take the risk. What are stock rear leaf springs rated for and what replacement leaf springs should I look into.
87Chevy3853 is offline   Reply With Quote
Old 05-05-2015, 08:10 PM   #2
Matt Man
Matt Man's Avatar
Re: hauling a UTV in a half ton
You should be fine, my 81 K10 short bed has a payload of 1350, a 2wd should have a little more capacity.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-05-2015, 08:13 PM   #3
greg64
greg64's Avatar
I have a 77 half ton. I replaced the rear leaf springs a year ago, because the originals were clapped out and broken. Not entirely sure on the original load carrying capacity, call it not too much. The new springs are generic part number 22-403, and they're rated for 2300 lbs. Well, that helped a lot. I've had 1500 lbs in the box with the new springs and it's no problem. There are other capacity springs available too if you go looking.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 05-05-2015, 08:16 PM   #4
87Chevy3853
Sorry forgot to mention its a V10 (4x4). Would a set of helper springs not be a bad idea since the originals 28 years old
Old 05-05-2015, 08:30 PM   #5
Matt Man
Matt Man's Avatar
Won't hurt at all. But since you only haul it a couple of times a year, I don't know if I would worry about it.
