Old 05-05-2015, 09:49 PM   #1
Ta12sec
Shackle flip/ axle flip
I have a 72 k5 4x4 the previous owner lifted the truck in the rear by installing a shackle flip kit in the rear. This involved cutting the factory spring hangers and installing new flipped ones . I need to bring the truck back to stock height to fit in my garage and also it looks kinda stupid with the rear wheel almost touching e front of the wheel well. Trying to find factory spring hangers isn't working out so I came up with a new plan, looking for thoughts on this idea.
The truck is roughly 5 inches over stock in the rear, I am thinking of doing a axle flip like you would to lower a sport truck. This would bring my rear end down a little over 5 inches. I would weld new hangers to the axle and put it on top of the spring pack. Can't really come up with a good reason not to so looking for outside perspective on reasons not to.
Ta12sec is offline   Reply With Quote
Old 05-06-2015, 08:34 AM   #2
Mike C
Mike C's Avatar
Re: Shackle flip/ axle flip
Personally, I would just keep looking for a donor trucks stock spring mounts. Or make a set same way the lift hangers are made.
Old 05-10-2015, 09:32 PM   #3
Ta12sec
Anybody have any thoughts on this?
Old 05-10-2015, 10:42 PM   #4
jjzepplin
jjzepplin's Avatar
This^^^. They are there and will bolt right in making life much easier and your truck much happier and stock looking. One small change usually means 3 other small changes and then a snowball effect. Be patient and do it right.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
