opinion
I hava GM Performance 290 hp 350 with a edelbrock 1406 carb. it's fed by a Holley blue 110 gph pump with a deadhead regulator set at 4.5 psi. I am switching to mechanical pump cause fuel tank is still in cab. Pump is working to hard. What are opinions on high pressure versus high volume pump, like from a old vette.
![]() Join Date: Nov 2001
Re: opinion
With a Edelbrock carb, you absolutely do not want/need high pressure.
Without high performance/high RPMs you do not need high volume. Edelbrocks website shows some mechanical fuel pumps for use with their carburetors.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
![]() Join Date: May 2007
Re: opinion
I would just buy a stock $20 pump. It will supply all the fuel your engine will ever need.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Re: opinion
With that engine there is no need for anything more than a stock pump. Save your money and just by a stock replacement
Re: opinion
Agreed no need for anything over 6-7 psi or you could overflow your bowls and potentially catch the truck on on fire.
________________________ 72 Olds Cutlass w/442 option 69 C-10 Short Bed Fleet 1960 Biscayne Wagon/El Camino 1995 YJ 4.0 SOA SYE on 35s 01 Excursion Limited 7.3 PSD 06 Suzuki DRZ 400S |
Re: opinion
that 1406 only need about 5 psi to work well anything much over that and it will blow off the needle and seat. Jim
