65 C10 gauge cluster ground?
I have rebuilt my gauge cluster & have a ground from each connector which is straight forward, problem is I took it apart in Nov. & have a separate ground wire from behind the cluster (grounded to sheet metal) that I marked as "to instrument cluster". Question is does the cluster itself require a ground wire over & above the two from the connectors??
Re: 65 C10 gauge cluster ground?
My understanding is from the factory, the cluster is self grounded being mounted to the steel dash. I have also added a ground from my cluster to the body though.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thanks, mine must have had a ground to the cluster added as well.
