Old 05-06-2015, 04:26 PM   #1
ufbugman
Got my tags and went for my first drive! and broke down
Got my tag for my 71,c10 and went for a ride, 1st stop 2 new lower ball joints pressed in, 2 stop wash at the car wash, 3rd new wiper blades, and then 4th stop got some gas, And then she would not start. dead battery, got jumped and drive home.
I pulled the alternator off had it checked and they say it fine, battery is good also. I hooked up a volt meter to alternator and with the truck idling I had 14 volts. when I deconnect the neg cable from the battery truck stalls.
any ideas?
2nd problem is shift linkage can't get it in park...
specs on truck... 71 c-10 327 with th400 till cpp column
ufbugman is offline   Reply With Quote
Old 05-06-2015, 04:43 PM   #2
Secret Squirrel
Secret Squirrel's Avatar
Re: Got my tags and went for my first drive! and broke down
Hot wire running from alt is bad? If it's a one wire alt did the plug on the bottom of alt fall out? I have heard that will effect it, but never tested the theory myself.
________________________
72 Olds Cutlass w/442 option
69 C-10 Short Bed Fleet
1960 Biscayne Wagon/El Camino
1995 YJ 4.0 SOA SYE on 35s
01 Excursion Limited 7.3 PSD
06 Suzuki DRZ 400S
Secret Squirrel is offline   Reply With Quote
Old 05-06-2015, 04:58 PM   #3
ufbugman
no it's the old 3 wire type..
Old 05-06-2015, 05:38 PM   #4
mahanian
C10 addict
mahanian's Avatar
My guess would be either it's a wiring issue from the alternator to the battery/fuse panel or the alternator is failing under load. I would double check your chassis grounds as well if the other two are fine.
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 05-06-2015, 08:08 PM   #5
ufbugman
Just tried something, dis connected all the wires from the aternator but ground and hooked up a test light to the battery termail on the alt, started the truck and nothing , should I have had juice?
Old 05-06-2015, 08:58 PM   #6
9teen69
9teen69's Avatar
I've had problems with these two wires coming loose and not starting, are yours secure?
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 05-06-2015, 09:27 PM   #7
RichardJ
DO NOT ever disconnect the battery with the engine running on a vehicle with an alternator. EVER
That is something some would do with the old DC Generators. It told them the gen was putting out some current, enough current to power the ignition, but it told them little.
>>then 4th stop got some gas, And then she would not start.<<
You might check the starter. Did the engine crank slowly, did the solenoid just click or was there no sound?
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 05-06-2015, 09:51 PM   #8
mahanian
C10 addict
mahanian's Avatar
Yes, you should have power out of it if your test light was grounded
Jared
67 Camaro RS
Old 05-06-2015, 10:32 PM   #9
ufbugman
ground wire for test light was grounded even tried it in a few spots...
Old 05-06-2015, 10:48 PM   #10
68350
68350's Avatar
The voltage regulator may have went bad too. Its on the radiator support by drivers headlight. I fought with my 72 GMC having a dead battery every once in a while. Checked battery and alternator and both checked out. Replaced voltage regulator and haven't had a problem at all since
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 05-06-2015, 10:49 PM   #11
mahanian
C10 addict
mahanian's Avatar
Sounds like a bad alternator to me
Jared
67 Camaro RS
Old 05-06-2015, 11:21 PM   #12
JustinGJ
Yeah, could even be heat soak on the starter after that many stops, are you running headers?
71 C-20 Custom Deluxe
350-TH400
Blue/white standard two-tone
92 K1500
350-4L60
Blue/white two-tone
JustinGJ is offline   Reply With Quote
Old 05-06-2015, 11:26 PM   #13
CG
BlahBlahBlah
Running a 350 with long tube headers on my off topic truck and I had a bunch of problems dealing with starter being way to close to the heat of the headers. Went to a smaller high torque starter and a little wiring work around and its been fine ever since.
I would go to town, do a few stop start errands and it would not start. Even had to have it towed home once =<
Old 05-06-2015, 11:44 PM   #14
Secret Squirrel
I've had that GM hot start on my 72 Olds, ended up going with gear reduction starter. Given the details the OP gave my money is still on the charging system.
When the external regulator went out on my Olds my lights got super bright then radio went out and car died (fried my electric fuel pump).
X2 on the bad/failing alt ... Dumb question but you didn't throw a belt did you? Lol I know I know I would hope the belt is on good and tight.
Old 05-06-2015, 11:50 PM   #15
ufbugman
belt is good and tight, I think it might be the alternator myself, advanced auto said it was good, but they also are not the bright bulbs in the package.
I think my last test with all the wires removed and a test light hooked up told me the alt.
But still going to check it again tomorrow before buying a new alternator
The starter is Fine
Old 05-07-2015, 12:22 AM   #16
tommys72
tommys72's Avatar
Same exact thing happened to me....replaced it, haven't had an issue out of since
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-09-2015, 10:49 PM   #17
ufbugman
got it figured out! the voltage regular was not gronded good, 2 new bolts and all is fine..
Old 05-09-2015, 11:57 PM   #18
Secret Squirrel
Awesome, glad to hear
06 Suzuki DRZ 400S
Old 05-10-2015, 12:12 AM   #19
In The Ten Ring
Oh geeze. I wonder what surprises await me when I go for a test drive........
In The Ten Ring is offline   Reply With Quote
Old 05-10-2015, 12:56 AM   #20
Ozzy2013
Ozzy2013's Avatar
Cool at least it wasnt serious
Ozzy2013 is offline   Reply With Quote
