![]() Join Date: Mar 2013
American Racing TT2 VN515
Good afternoon,
Quick question for the members, I have search and not been able to find anything. Is anyone running the AR TT2 on their trucks? If so, could you post a picture? Also, I am wanting to run a square setup. I'd like to run a set of 18x9's all around. Will a 9" with a 5" BS fit up front? If not, a set of 20x8's on front and 20x10's in rear. Thanks for the help! |
Re: American Racing TT2 VN515
They fit. I picked them up this morning. The computer said they wouldn't fit, but they sure do. It said the load rating was not acceptable. It had the load at each wheel at 2700#. Triple checked loads and it works fine. Plenty of clearance front and rear. I am thinking 255/50/18, 265/45/18, or 275/45/18 all around. The 265 is a little shorter than I'd like at 27.4 and the 275/45 is a spendy tire. the 255 is where I want to be at 28", but they are hard to come by. I have a line on some leftover Toyo Proxes in 255 that I may run and switch to a different size when they wear out.
