Old 05-06-2015, 10:41 PM   #1
hotrod66
hotrod66's Avatar
6 cyl throttle linkage help.
I have a Offenhauser intake and a 500 cfm 2 barrel carb .I was wondering if had a similar setup would share there idea of how to hook up the accelerator to my stock pedal,linkage. Any help would be appreciated.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 05-06-2015, 11:02 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: 6 cyl throttle linkage help.
Could I have a picture of your setup?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 05-07-2015, 01:12 PM   #3
NEWFISHER
NEWFISHER's Avatar
I used a Lokar cable and have fabbed a bracket for the stock pedal, used a Lokar pedal and also used a 67 up pedal and l bracket through the fire wall. It's easiest to order a carb bracket, cable and pedal. On a budget, it takes a few trips to the wrecking yard. You might also look at the 80s throttle cables with the square firewall clip on the sheath. We just used one on a buddy's rat rod and it worked too.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 05-07-2015, 01:46 PM   #4
jcramsey
jcramsey's Avatar
I've got a holley 390 on my truck so I guess if you have your 2 barrel turned with the throttle towards the front it would be the same. Mines not pretty or elegant but it works.
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 05-07-2015, 08:21 PM   #5
hotrod66
hotrod66's Avatar
Here's the carb set up guys
Old 05-07-2015, 09:06 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
Here's a picture of what I did. You have a clifford intake by the way.
Old 05-07-2015, 09:14 PM   #7
hotrod66
hotrod66's Avatar
Yeah I don't know why I stayed offenhauser lol guess because it's more fun to say. Thanks everyone.
