Old 05-08-2015, 01:15 AM   #1
RedRoad
RedRoad's Avatar
Source for NoSpin parts?
Looking for a single spring retainer for an early NoSpin (Detroit Locker) for a HO52/72. Looks like someone tried to "repair" a cracked one but not very well.
Any leads appreciated
RedRoad is offline   Reply With Quote
Old 05-08-2015, 01:21 AM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Source for NoSpin parts?
Contact board member tll74 or DLTruck1973.
They are actually one in the same and should be able to help you with any part or service you need on a rear end.
Thank you,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 05-08-2015, 06:43 AM   #3
I believe Eaton still supplies parts. check any differential merchant like Randy's Ring & Pinion. try googling Detroit Locker replacement parts.
Old 05-11-2015, 05:05 PM   #4
RedRoad
RedRoad's Avatar
No luck at Randys or Tom so still looking.
Old 05-12-2015, 05:56 AM   #5
Contact Eaton directly. If they don't sell to public they can give you a dealer contact. Maybe parts stock is depleted, but I read a while back Eaton was where you get parts
http://www.google.com/url?sa=t&rct=j...,d.eXY&cad=rja
I should try myself. I have a No-Spin that I somehow lost one of the springs to. I pulled it because of an issue and I suspect it was a spring or both. That may be what caused your side gear issue...weak spring? Mine acted like a go cart, one side was solid full-time locked. It was worse than bias. It wouldn't back up in gravel if there was any slope to it. I just popped another one in, but would like to get this one together.
Old 05-12-2015, 01:35 PM   #6
RedRoad
RedRoad's Avatar
I have emailed Eaton with no response so far.
With a new 14 bolt detroit costing $425 and easily sourcing some 14 bolt axles it may be the better way to go but I REALLY would like to make this work.
If you were to consider selling your partial unit let me know
Old 05-13-2015, 03:08 PM   #7
RedRoad
RedRoad's Avatar
Finally got a response from Eaton, no luck.
Any partial lockers wanted
Old 05-13-2015, 09:23 PM   #8
I don't understand how they could have no replacement parts unless they scrapped them. I mean, both HO52s and No-Spins have reputations for being bulletproof even still, after 43 years.
Old 05-14-2015, 12:12 AM   #9
RedRoad
RedRoad's Avatar
They said "I am sorry but this style of unit has not been made it a long time and there are no parts available."
Randys also said no parts available. I asked for a quote for a 14 bolt detroit and axles and they replied with $1300 plush shipping!
A detroit and axles are only $800 at Summit with free shipping. I could save some cash shopping around on CL or yard on the axles and save $300.
As much as I want to keep the HO52 under the burb the 14 bolt is looking better all the time
Old 05-15-2015, 07:42 AM   #10
i hear you. I'm a diehard HO52/No-Spin guy. Seeing this day come I have grabbed rears where I found them. I may be good to go or I may find myself stuck in this situation one day. I guess that's why I'm also hanging tight with a same ratio 14-bolt I had planned to put in my '85 Jimmy when I put the Dana60 in, but just sold it as is
Old 05-15-2015, 08:28 AM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
If time isn't a big issue post a WTB on the parts board. I know an HO with a NoSPin was advertised in the recent past for sale. I was able to locate the parts I needed for my HO52 with some scrounging and some help from the folks here. Good luck.
Old 05-15-2015, 11:44 AM   #12
jeffahart
jeffahart's Avatar
I have a locker on my workbench out of an HO52. I'll make you a deal, you can come get it. I see you are in Los Angeles.
White K20
jeffahart is offline   Reply With Quote
Old 05-15-2015, 02:02 PM   #13
RedRoad
RedRoad's Avatar
Id appreciate that! Shoot me a PM with what you are asking and Ill see If I can make it happen.
THANKS!!
Old 05-15-2015, 02:29 PM   #14
jeffahart
jeffahart's Avatar
THANKS!!
Sent you a PM. I got some new wheel cylinders too. It will be Xmas for you!
White K20
Old 05-17-2015, 12:01 AM   #15
obijuan
i have a chewed up ring and retainer in a locker. i need one of those too. anyone got one for sale?
obijuan is offline   Reply With Quote
