Old 05-08-2015, 03:03 PM   #1
Nickb90
Drive shaft replacement
Looking for suggestions on replacing/repairing the drive shaft in my '64 c10. Its a 2 piece shaft & the front shaft broke right where it goes into the carrier bearing. Just trying to see what others have done for replacements. I'd like to keep the price low as low as possible on this, but also to want to go too cheap & have it brake again.
Nickb90 is offline   Reply With Quote
Old 05-08-2015, 03:41 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Drive shaft replacement
Is there a local drive shaft specialist in your area? I usually find it easier and cheaper to work with a local drive line shop in my area for these types of things.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-08-2015, 07:27 PM   #3
63burban
Chevy addict
I have some used two piece shafts in good condition.
63burban is offline   Reply With Quote
Old 05-08-2015, 09:54 PM   #4
Nickb90
Would you be able to check the length of them? I'm looking for a font section that's 27 inches weld to weld. Total length is 68 inches yoke to yoke.
Thank you
Old 05-09-2015, 10:21 AM   #5
jayoldschool
Moderator
Did the shaft break, or the yoke?
jayoldschool is offline   Reply With Quote
Old 05-09-2015, 11:05 AM   #6
earl84
I agree on staying local, I never had to do driveshaft work before and was shocked at just how inexpensive it was to have them shorten, balance, paint and install new U-joints.
earl84 is offline   Reply With Quote
Old 05-09-2015, 08:39 PM   #7
63burban
Chevy addict
The shafts I have are longer, you could have one cut down
Old 05-10-2015, 12:21 AM   #8
Captainfab
60-66 Nut
Probably should determine whether you have the light duty driveshaft or the heavy duty driveshaft. The light duty driveshaft will have the carrier bearing hanging from the top of the trailing arm crossmember. The heavy duty driveshaft will have the carrier bearing sitting on a bracket on the bottom of the trailing arm crossmember.
Old 05-10-2015, 12:35 PM   #9
Nickb90
Thanks for looking... I think I'll take what I have now into a driveline shop & see what it will cost to fix mine or get a custom built. Hopefully they won't want an arm & a leg for it. Again thank you for the offer!
Old 05-10-2015, 12:37 PM   #10
Nickb90
It broke right behind the weld, before it goes through the carrier bearing.
Old 05-10-2015, 12:43 PM   #11
Nickb90
I didn't know that there was a light & heavy duty shaft for these. Looks like mine is the light duty (carrier bearing was mounted from the top of crossmember). What is the difference in these driveshafts, just different carrier bearings or are the shafts completely different?
Old 05-10-2015, 11:59 PM   #12
Captainfab
60-66 Nut
The HD carrier bearing is much, much better than the light duty one and the driveshafts are made from larger diameter tubing.
