Old 05-08-2015, 03:40 PM   #1
scott 62
steering help
I have a 62 k10 suburban that I installed a power steering kit i did all the mod's I learned form this group. my problem is severe bump steer HELP i do believe the springs are stock. do i need to install a heavy sway bar?
scott 62 is offline   Reply With Quote
Old 05-08-2015, 04:25 PM   #2
VonDog
VonDog's Avatar
Re: steering help
Check all your steering components ie. tie rod, drag link, etc. for any slop. My buddy has been having issues and his tie rod ends were shot along with some other stuff. He put on new ends, shocks, drag link, steering stabilizer, and finally tires. All that seemed to do the trick.
VonDog is offline   Reply With Quote
Old 05-08-2015, 04:36 PM   #3
scott 62
Re: steering help
all the tie rods and link is tight i have a stabilizer and good shocks and tires
Old 05-08-2015, 07:01 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: steering help
...sounds like you are gonna install that heavy sway bar sooner or later anyhow...that'll tell you if that will cure the bumpsteer, won't it...sounds like something I'd try.
Sam
luvbowties is offline   Reply With Quote
