Stupid radio Problem
ok, so my radio works great......until i hit 35 mph then i dont hear any sound coming out of the speakers. Radio still has power. Looks like it is working. No sound. take foot off the gas. trucks slows down, right when it get to 35 mph and less, sound comes back on. WTF?????
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
Re: Stupid radio Problem
i'd check the antenna
It even does it when I'm using a USB drive to get music. Could it still be the antenna?
>>Radio still has power<<
By that I assume you mean the radio lights are still on. Connect a volt meter so that you can read it while you drive. Either bring two wires in from the battery or connect at the radio fuse and a ground near the radio. For it to be so precise at 35 mph, I suspect a voltage problem. Possibly an over-voltage problem and the radio has an over-voltage protection circuit.
'67 GMC 2500, 292, 4spd, AC |
![]() Join Date: May 2014
Sitting still slowly rev the engine through its RPM range and see if it does the same thing.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
Turn up the volume....
1972 K5 CST |
It does not do it when sitting with RPM's. I was thinking an over voltage is happening. It's weird. The display still shows all the same stuff. Just no sound.
Posted via Mobile Device |
![]() Join Date: Feb 2002
Think maybe you're getting some RFI from ignition components when you get into a high RPM regime? There used to be coils and capacitors and shielded plug wires to shield AM and FM signals from the hash.
x2, the wind may affecting it. turn the radio on and go out and move the antenna. (while sitting still of course)LOL...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
>>It even does it when I'm using a USB drive to get music.<<
Obviously not an original radio and also obviously not in the tuning section of the radio.
