Full disassembly when sandblasting?
I mean how far should you go? Keep entire cab and quarter panels intact and blast or take every nut and bolt apart and blast then put back together? If so, can you put it back together again? I've attached several pictures of current rust removal and rust to be removed and patched.
I want a fairly rust free frame and body to perform body work and then paint a thick arse coat of paint to help cover some of my lack of perfection or lack of experience Do not need professional paint job. Mechanically I want it solid. 383 stroker 450hp from local engine shop. |
Re: Full disassembly when sandblasting?
Anyone?
Bueller?........Bueller?........Bueller? |
#3 | |
![]() Join Date: Jan 2015
vehicle's I own 1968 gmc 3/4 ton camper special 1972 gmc jimmy 1972 Chevrolet nova 1947 ford 1.5 ton dully 1997 f-350 1 ton 2007 Chrysler 300 with hemi |
Was it a Blazer?
Did you blast then repair assuming you needed to do panel repair and replacements like rockers etc..? How hard was it to get everything lined back up. Did you use a rotisserie. |
Actually after re-reading your post it looks like your currently disassembling your truck correct?
![]() Join Date: Apr 2006
I think it comes down to how much time you want to spend. If you have only weekends and it's just you be prepared for a lot of weekends dedicated to working on it. It's the best way to do it but you might not be driving it for a couple of years.
Kirk 72 Blazer CST 4wd highlander |
