user # 2756
![]() Join Date: Jun 2001
On my 70 GMC w/ 4 wheel drums, I went to replace the MC and have been stumped ever since. I attached some pics of what I have. The booster was on the truck prior to me getting it in 1999. The MC I got does not work with the booster, not sure what the booster is from or what year MC to ask for. Hopefully the pics will help. I have the booster as installed, real short rod. A booster from a 71 chevy and pics of the new MC. Help me out. Thanks,
Jim
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
user # 2756
Re: brake mc/booster help
It almost looks like a booster from a new truck?
Isn't that mc a manual brakes Mc(the deep bore in the back)? If so is the rod long enough to engage the Mc? What's it exactly doing?
1969 Chevy c20(Miss Hackjob) |
Old member
I think you need the extension rod placed between the booster and MC. That should fix it.
![]() This looks to be correct booster.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
user # 2756
The rod is not hitting the MC piston. I bought a MC for a 72 K20 and it has a small dimple for the rod to engage.
