Starter issues
So I replaced the starter on my 70 c10 with a 383 stroker motor. The starter I replaced would spin but nit engadge with the flywheel. I replaced it with a new starter and it is doing the same thing. This is a stock style starter not a high torque. Any ideas as to what it could be or that I need to do??? Thanks for the help.
Stalker Nate
Re: Starter issues
Is it shimmed, in the right holes, right tooth count for flywheel? It should engage if so and new. You bench test the starters before install? Does it make a screaching sound or just spins silently so to speak.
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
Re: Starter issues
Make sure you use the brace that goes on front of starter to block ,cured my problem same starter for 5 yrs. And it Helps to get a quality starter
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Re: Starter issues
Makes a screaching sound
Re: Starter issues
Actually more like a loud grinding sound
Stalker Nate
Re: Starter issues
So not in alignment then. It'll make that sound when it's either partially loose or not in proper alignment. Does it bolt bottom up or side mount? Lots of aftermarket starters have 2 sets of bolt holes for bottom up mounting so confirm you have it bolted in right. Next would be make sure it's actually inline with the flywheel. May need to shim it or take shims out if you have some in. Trial and error but it's pretty simple at least. Just a pain taking it off each time lol
Re: Starter issues
Ok I will take it down and check allignment. Thanks
![]() Join Date: Apr 2012
Re: Starter issues
It's possible to have a starter that needs more shims on one bolt than the other. Ask me how I know
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
