Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-10-2015, 03:12 PM   #1
Super73
Super73's Avatar
9.58 @ 138.86
Well got some passes out yesterday.
Best motor pass was 10.6x @ 126.x with a 1.64 60'.. Changes from my 10.38 pass:
Went from 4.56 gear to 3.90
Went from 254/260 cam to 259/274, gained overlap which I am sure moved peak TQ up in RPM
took 100lbs out
I attribute the slow down to the gears, cam, and converter (4,800ish on motor) not being optimized together, well, at least for motor passes.
First try at a bottle pass, the controller did not come on. Having fought with controllers in the passed, I bypassed it as I didn't want to be screwing with it all night. I think I have an EMI issue under WOT.
Rolled in to the throttle to make sure things were good and cut a whopping 1.73 60' but ran my best MPH ever, 139.56 with a 9.9x.. Well that was very promising.
Next pass I tried off the transbrake and the motor pulled an additional 10* timing due to false know. It fell flat on its face and I aborted the run.
I ran it off the the foot brake again rolling in a little harder and it went 9.9x again at 138.x.
Tightened the front shock 2 clicks and went off the t-brake again. 9.58 @ 138.86 spinning. It is lifting both fronts and unloading the radial on the way down. Slip attached.
Tightened the front shocks 2 more clicks (now fully tight) and tried again. This time it blew the tires off even harder (2 cars with street tires went before me).
By this time is was 9:35 and track closes at 10:00. I decided to wrap it up and be happy with those results.
Here is the video of my 9.58 pass, both full speed and slow motion.
https://youtu.be/vn-84-eGQro
https://youtu.be/nCLwqktVa-I
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-10-2015, 03:33 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: 9.58 @ 138.86
Interesting I only saw tire smoke of the left rear tire out there around the 60.
Hey,, she made passes and your not tearing it apart to fix something!!! The bad luck seems to be over!!!! YEAH!!!!!
I expect more MPH out of her for 9.5's Did you roll out of it early?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-10-2015, 04:10 PM   #3
northern 85
northern 85's Avatar
Re: 9.58 @ 138.86
Nice pass
northern 85 is offline   Reply With Quote
Old 05-10-2015, 05:28 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 9.58 @ 138.86
You can have those radials , i'll pass on chasing my tail .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 05-10-2015, 05:56 PM   #5
Super73
Super73's Avatar
Re: 9.58 @ 138.86
Marv,
Very happy it came home with the only thing "needed" being an oil change. Pass was more like a 9.60 being 9.58, but my buddy Dan asked me the same thing. Remember it went 9.82@132mph previously.
Hotrod,
I am sure it would work fine with a 10.5w as a slick is a goods bit more forgiving. I will get it sorted out at some point. When I get it to go 8.9x with the radial then I might consider putting a slick on it.
Old 05-10-2015, 10:28 PM   #6
Marv D
Marv D's Avatar
Re: 9.58 @ 138.86
The visor over the windshield and the big ol squared off front end makes it aerodynamically challenged for sure.
Using the conversion
(1/8 ET + 0.22)/ 0.655 you should be at 9.61,, she is meeting the 'normal'.
I think you just need to put more pill in it (LOL)
Old 05-11-2015, 12:10 AM   #7
Super73
Super73's Avatar
Re: 9.58 @ 138.86
Let me get the 60' dialed and I will put the second stage on it. I will be ordering a new pair of front springs in the near future.
Old 05-11-2015, 02:40 AM   #8
BigDan3131
BigDan3131's Avatar
Re: 9.58 @ 138.86
Were the gear and cam changes made for when you go turbo? Are you hitting your peak power numbers thru the traps? Even if you haven't the time to get the glass front end, what about a glass bumper at least to slightly decrease your frontal drag. Has your chassis guy said anything about 4 link changes? I would get everything nailed down with the first stage then go on to the second because you may end up softening things with more power.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 05-11-2015, 10:46 AM   #9
RICKSRAT
RICKSRAT's Avatar
Re: 9.58 @ 138.86
Hey Super glad to see you got to track. What kind of controller you running and what pills you have in. And looks like you need to update signature. Congrats
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30
Old Motor: 60'. 1.43
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
RICKSRAT is offline   Reply With Quote
Old 05-11-2015, 11:26 AM   #10
Super73
Super73's Avatar
Re: 9.58 @ 138.86
Dan,
The gear had to be changed regardless. I want to go 8.90 on the bottle this year before I consider switching to the turbos. I have unfinished business with the N20. I think I am going to need 153mph to reach my goal. Even with the new 3.90, I am at 6,800 almost 6,900rpm going through the traps right now at 138-139mph. This has me a little concerned about the 3.90 gear I put in it. The old cam peaked at 6,900-7,000 and I am guessing the new cam might carry a pinch further but I have not had it on the dyno yet. This cam is definitely not a "turbo" cam. 259/274 on a 109icl with a 113 lsa.
I won't have time this month to mount the front end for the race June 2, but going to try and get it mounted before the July race.
I talked to my buddy who is pretty good with chassis, he was actually at the track with me. The only change I thought we might be able to try with out changing parts (but thought of it on the way home) was changing the IC to be a little shorter. This would increase antisquat percentage and could slow the front rise down. But.. That increases initial hit on the tire. I feel it might be ok since it is dead hooking out of the hole for the first 3-5'. He wasn't sure how it would react with the radial, might start to get to violent.
I plan on getting the 1st stage dialed before adding a second.
Rick,
I have tried a NOS launcher and now have a Modotek (Daytona Sensor NC2) both work in the garage, but don't work at the track. I believe I have an EMI issue with my plug wires. In doing some dyno testing, I went from a stock wire to a Granatelli as they have a nice thermal wrap around the boot, claim 20rwhp gain and give a lifetime warranty. Skeptical of the hp claim, I did a back to back dyno with no changes to the tune and picked up 19rwhp but my usb mouse no longer worked with the truck running. Swapped back to OE wires, lost the power but the mouse would work again with the truck running. Back to the new wires, again gained the power but mouse was dead while the truck was running.
The NC2 has a live view/data logger function. The RPM lines up with my tach and ECM read out at idle, but the minute you give it throttle, it is extremely slow and does not read properly. Perhaps I need a filter for the controller with these wires. I am going to test with OE wires and the noids disabled.
Old 05-11-2015, 05:35 PM   #11
RICKSRAT
RICKSRAT's Avatar
Re: 9.58 @ 138.86
Super , The Daytona system looks like a nice piece and I like the logging. Just a thought but is your progressive wiring in a separate wire loom so not to get feedback from any other wiring. Like thought of the "unfinished business" with the n2. Kinda where I am right now myself. What are you thinking N2 HP wise to get you to 8.9x.
I bought a Leash progressive for mine. Also will be on a 315 drag radial now and will need to go to a 3.90 from a 4.30.
1/8 6.58@104.64
1/4. 10.42@127.10
Nitrous: 60'. 1.28
1/8. 6.15@ 112.02
1/4. 9.75@ 136.32
Old 05-11-2015, 06:53 PM   #12
Super73
Super73's Avatar
Re: 9.58 @ 138.86
Well just weighed the truck and it sure makes sense as to why it unloads the tire once the front starts coming down weight is with me in the seat:
3,120 total
1,820 front
1,300 rear
I will be ordering some new springs shortly.
Rick,
I think once everything is sorted out on the first stage (78n jet, showed 170rwhp on a chassis dyno), I think it's got a 9.4x in it. With that said, I am planing on putting another 200rwhp worth on it. Might detune the first stage to a 100rwhp hit when I add the 200 second stage until I get it sorted. But I'f I can't go 8.9x with that, well, I am not sure what to do
Old 05-11-2015, 08:30 PM   #13
low69chevy
low69chevy's Avatar
Post Re: 9.58 @ 138.86
Nice, truck takes off hard
low69chevy is offline   Reply With Quote
Old 05-12-2015, 08:13 AM   #14
regan wilson
regan wilson's Avatar
Re: 9.58 @ 138.86
That mph is similar to what mine was at that et. Theres alot to be had in the 60 ft though! That 6.09 1/8the mile with only a 1.49 60 says its running very good. A set of slicks could put it in the fives.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 05-12-2015, 11:44 AM   #15
Super73
Super73's Avatar
Re: 9.58 @ 138.86
I ordered a new spring. Ironically it is the same morosso 47140 I used to run at 3,8xx lbs. I know I am going to have to trim it to get my stance and that will make the spring stiffer than the advertised 240lb rate. We will see if it shows it down enough.
Old 05-12-2015, 01:49 PM   #16
PGSigns
PGSigns's Avatar
Re: 9.58 @ 138.86
What shocks are on it front and rear? One thing it needs is limiters on the front. Also put the tailgate back on it you need the weight. One thing I saw was it looked like the front came up to far and there was not much of any seperation in the back like the rebound is to tight. It also settled on the tire pretty quickly and that may be a soft compression setting. A shorter instant center will hit the tires quicker but may not keep them hooked. What is the instant center height and length now?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
