Bell Tech or CPP - 72 SWB
Wanting to order a 3/5 drop for my 72 SWB this week. Was wondering if there are any benefits, issues with either vendors product. Bell Tech makes a 3 inch drop spindle for the front, CPP uses a drop spindle and shorter spring to achieve the 3 inch drop on the front. Any input would be greatly appreciated. Thanks
Re: Bell Tech or CPP - 72 SWB
I think you'll get a lot of responses voting for ECE's kits.
Here's some related discussions to help with your decision: http://67-72chevytrucks.com/vboard/s...d.php?t=656568 http://67-72chevytrucks.com/vboard/s...d.php?t=656449 http://67-72chevytrucks.com/vboard/s...d.php?t=636386 |
Thanks for the response in regards to ECE. I've read alot of good things about them. The only thing is I believe you would have to go with a 2.5 or 3.5 drop on the front. Wanting the 3 front 5 rear look. With that said a Big Block stroker is going in it so maybe the 2.5 front drop with the additional weight of the Big Block may give it the look that I am looking for (not sure).
I run cpp front springs and have had no issues with them.
consider what brakes you want to run, I believe CPP's spindle will allow future plans while the Bell doesn't.
'68 C10 SWB '85 K30 Blazer |
I would use ECE and not fuss over 1/2". Can you really tell the difference? The 3" drop spindles are a bad idea for normal diameter rims
Thanks for the responses.
Moderator
![]() Join Date: May 2007
Whatever vendor you use, they will most likely sell you Western 2.5" dropped spindles, which are the most commonly used brand for 71/72 trucks. I have never had an issue with them. I would avoid 3" bell tech drop spindles for the reasons mentioned above.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
