05-10-2015, 06:07 PM | #1 |
widening steel wheels
How wide can I go front and rear with everything stock? Inner fenders, rear wheel tubs, everything is factory. But I'll be lowering it 2 and 4. 72 2wd 1/2 ton lwb. I'd like to 7 or 8 inch wheels in the front, 10 inch in the rear if possible .Thanks for any input.
Tom
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
05-10-2015, 07:59 PM | #2 |
Re: widening steel wheels
if you have the proper backspace should b no problem at all// I did a cion with the same drop and used 8"in front and 10 in the rear with a 4.5 inch backspace on both without any problems at all
05-10-2015, 08:05 PM | #3 |
I have a friend that had a 67 or 68 that he had 12 inch rally wheels on the back. you will have no trouble with 8's and 10's I'd say. Jim
05-10-2015, 09:28 PM | #4 |
We're they sticking past the fenders in the rear?
05-11-2015, 04:36 PM | #5 |
I have 2 15x9 custom stock rims.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
05-11-2015, 07:24 PM | #6 |
Yeah it seems it did stick out , He had found a place in Memphis TN to stretch out the wheels and he had some 12's and even tried some 14's but I think it was a failed project and he stuck with the 10's. Back then though it didn't look out of place to have tire out past the fender. Jim
05-11-2015, 08:25 PM | #7 | |
05-12-2015, 06:53 AM | #8 |
If you don't lower the rear 10s will fit fine. They fill out the well and (the tread) don't stick out. 10" looks good, till you get into lowering (looks good if fits), then it's real close and depends on tire and backspace. I'm doing 8" all around with same size rubber so I can rotate, 4/6 drop. But, for around town having fun I want a pair of 10" with drag radials on the rear.
I just saw this in the next thread I went to. Looks like 10" rear wheels for sure: http://lasvegas.craigslist.org/cto/5019228910.html
05-12-2015, 11:22 AM | #9 |
Thanks Tim, sounds like I'll need to do some checking with a 4" drop inthe rear. Might just go with 8 and be safe.
05-12-2015, 10:31 PM | #10 |
Yeah, I had 10s on the back of a '78 SWB, don't recall tire size but were wide. I had a drop kit and couldn't install till I lowered it (with a Rancho flip-kit). I've had 10s on lowered trucks with more backspace.
05-12-2015, 10:38 PM | #11 |
If Marsh Racing is still in business, they used to widen steel wheels.
http://www.mrt-wheels.com/
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
05-13-2015, 12:25 AM | #12 |
I'll give them a call, not to far away
05-13-2015, 01:42 PM | #13 |
I agree, 4 of the same wheel is the way to go. Even more so on lowered trucks cause you see less of the wheels.
15x8 stock rims is the easiest way to go. I you want 2 15X9 for the back I can hook you up. Cheers
05-13-2015, 09:55 PM | #14 |
You can buy off the shelf 15 x 8 5 on 5s from Wheel Vintiques.
05-13-2015, 11:03 PM | #15 |
I have 10s on the back of my 68 step-side with about 3" drop and they don't scrub.
I also have M/T Sportsman 29x12.50s and the tires do stick out from the outer edge of the fender about 1" on each side. The fender is only about an inch or 1.5" above the tire and you would think they scrub but they don't. I did have some street-tread 31x10.50s on there and they didn't stick out at all. They stretched out on the 10" wheels though. Those 10.50 tires are really for 8 or 8.5" wheels. It's also a 5-lug 71-72 rear-end which I think is a little wider than the earlier 67-70s and the wheels have 4 or 4.5 backspacing. I have some pics on here somewhere but not from a good angle to see how close the tires are. |
05-14-2015, 12:23 AM | #16 |
I saw those Tim, look real nice. Not cheap though! I found a tire and wheel shop today that well widen mine for 30 bucks a wheel. So I think I'll go 15x6 in the front and 15x8 in the rear..I think it'll look pretty good.
05-14-2015, 12:26 AM | #17 | |
05-14-2015, 08:01 AM | #18 | |
Tom... I am running 15x10 with a 4.25 BS on the rear and 15x8 on the front with 3.75 BS... I am dropped 5.5" front and 7" rear... my wheel tuck in nicely... now with that said the 67 Rear end is 1" narrower that the 69-72 but that should not make them stick out from the wheel well...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
05-14-2015, 09:05 AM | #19 |
Nice, that looks good. I really do want that big and smaller look
05-14-2015, 09:48 AM | #20 | |
http://www.g3gm.com/t9331-how-i-did-...wheels-at-home K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-14-2015, 09:57 AM | #21 | |
What size tires are you running in this picture?
05-14-2015, 11:18 AM | #22 |
Good job Keith. That looks really good. I want to center to be further back. So I assume the cut out the centers and move them back with the new material added in the back.
05-14-2015, 12:36 PM | #23 |
Fronts are 235/70, rears are 295/50... on the front though I am probably going to change to 235/60... for me it is just a hair too much sidewall....
