cpp cnotch clearance
I cant seem to find. How much rear axel clearance will I gain when I install a cpp c notch. I currently have about one inch. I am using 4 inch springs and 2 inch blocks. 65 lwb c10
Re: cpp cnotch clearance
Half the frame. About 2". I used a pipe cut for 2.5" for my '62. Any bigger you need a bridge. That's a lot of drop.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
My reason for asking is I am getting ready to do a disk conversion in the front and am going with 2.5 inch lowering spindles. I am also looking at bags in the rear. I like the current stance but would like to go a little lower overall.
bump
Shocks keep me from full drop. 2 more inches before notches hit.
