05-10-2015, 09:57 PM | #1 |
One of the First
Changing axles, front dana 44
I'm rebuilding my front Dana 44 axle. I have 1972 D44 with the small u-joints and will be installing the 1973 and up larger u-joints axles. I see there is differences in the axles where the stub axle inserts into spindle and there isn't a machined shoulder on the longer axles for a slinger, plus If I understand right, I have to use this Spicer kit, 706527X instead of seals. The question, can someone offer some insight on how this will go together. I see and think I understand how it will go together. Just not 100% sure.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
05-12-2015, 03:34 PM | #2 |
One of the First
Re: Changing axles, front dana 44
Wow! For a bunch of off- roaders, I figured this would be a rather common exchange. So, this what Im looking at: On the stub shaft, it gets the metal slinger installed, the V-seal fits on the shoulder wear the metal slinger is pressed onto, seal lip facing the spindle and then the plastic spacer on the shaft. Question, is there a seal that fits oil/grease seal that is pressed into back of spindle? On the 72 models there is a seal.
05-12-2015, 04:03 PM | #3 | |
- Smaller seal goes behind the roller bearing with the V towards the ujoint If your spindle uses the roller bearing the little black seal has to sit behind it but people either don't drive the bearing deep enough to do this or just don't add it. If the bearing isn't deep enough just get a socket that fits the edge of the bearing and tap it down deep enough. You can see hear what I'm referring to: http://www.pavementsucks.com/techimg/dana44hub11.jpg I just did all this on my 74 |
05-16-2015, 12:33 AM | #4 |
On my D60, the seal used to seal the back side of the spindle is actually part of the axle assembly. It's just a rubber seal that slides over the stud shaft before installing the spindle. Sorry, been a while since I messed with a D44
'68 C10 SWB '85 K30 Blazer |
05-24-2015, 04:17 PM | #5 |
Born Psycho
Dave,
i use the 73 up axles on all my trucks but you need to use the spindles from the 73 up too. 73 up are machined on the inside to accept the rubber flapper dust seal, your 72s aren't machined since they use a "pound in" seal. if you have any ????? shoot me a call and i'll explain it more better. i talk much better than i type
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
05-25-2015, 07:52 AM | #6 |
One of the First
Thanks Jerry! that is what I was thinking, but I haven't had the time to do more research to verify. I will give you a call this afternoon. D/
06-09-2015, 09:13 PM | #7 |
One of the First
Finally got this completed, not a lot of info out there to ensure all the parts is on-hand to make the change over. It was rather easy, so here is the parts numbers and some explaining:
Dana Shafts: Long: 27902X Short: 27901X Outer stub axle: 41677 (2ea) Slinger: 36364 (2ea) – Pressed onto Outer Stub Axle Seal Kit: 706527X (2ea) Dust seal rides on Slinger shoulder, thin side facing spindle. U-Joints: 5-760X (2ea) Spindles: 706528X (2ea) 1973 – 1976 spindles. You have to use these because the inner surface is machined smooth, polished for seal kit. See Jerry Moos explanation ^^. Bearings: Set-37 and Set 45 (each side) Hub Seal: 422380 (each side)
11-01-2017, 03:54 PM | #8 |
All about them K’s
Subd thanks for listing those part numbers!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
11-01-2017, 07:53 PM | #9 |
And thanks for bringing this back. I never saw it for some reason.
