09-01-2003, 08:10 PM | #1 |
Keepin an eye out
rebuilding calipers...
is it hard, need special tools? Or should I just buy new or remanufactured..or does anyone have 73-8? for 1 1/4" discs for sale in working condition? Thanks as always.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
09-01-2003, 08:20 PM | #2 |
why bother rebuilding when it's so cheap to replace??
09-01-2003, 08:38 PM | #3 |
They're like 14 bucks a piece from NAPA!!!
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
09-01-2003, 09:40 PM | #4 |
Yup best thing that ever happened to auto parts. Those things are dirt cheap. You can afford to change them everytime you fill your gas tank...
09-01-2003, 10:09 PM | #5 |
Project92 SWB stepside
Cheap but yet easy to rebuild. Take a air chuck and you can blow the piston out. Be careful doing this as the pressure will SMASH the hell out of you hand if in the way. Put a piece of wood in to catch it. I bought a new set of calipers then pulled them apart and smoothed themout then powder coated them. Turned out pretty slick. This is alot cheaper than buying a high dollar calipers when mainly all I was looking for was looks. If you are not worried about this and you are just looking for a rebuild and not perfection then the (REBUILT) caliper is the way to go.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
09-01-2003, 10:43 PM | #6 |
Keepin an eye out
Good, will get some new ones
09-02-2003, 08:14 PM | #7 |
Smoothed factory caliper.
