Old 05-11-2015, 11:15 AM   #1
Jonlopes
Bumper bracket mounting questions
One of the first mods I want to do with my truck is replace the step bumper with a normal chrome “Sport” bumper. I think they look better and it will allow the longhorn to fit in the garage a little easier. Unfortunately when I crawled under the truck I found the PO both bolted and welded the brackets to the frame:
He also welded a piece of angle iron to the ends of the frame rails
And to the angle iron he welded a pretty heavy duty bracket that goes to the towing receiver.
So I have a few questions for the experts:
First; I was thinking it would be fairly easy to remove the welds with an angle grinder. Is this a good idea or should I just go to a weld shop and have it unwelded correctly?
Second; would I need to remove the angle iron brace or can I leave it in place? Or in other words can I mount the bumper brackets to the outside of the frame?
Third does anyone have any pictures of how the brackets go on a long bed leaf spring truck?
Thanks!
Jonlopes is offline   Reply With Quote
Old 05-11-2015, 11:24 AM   #2
jessemthompson
Re: Bumper bracket mounting questions
I would personally break out the grinder.
jessemthompson is offline   Reply With Quote
Old 05-11-2015, 12:05 PM   #3
wbc409
I would just break out the grinder. Be careful and don't grind to much off of the frame
wbc409 is offline   Reply With Quote
Old 05-11-2015, 12:16 PM   #4
Davidf
Looks like a thoroughly installed and strong bumper. Agreed, cut through welds. Personally, I like using an air cut off tool. Much easier to control than an angle grinder and it cuts through the weld much faster. I even use the cut off tool for rough grinding once the pieces are separated. Again, the air cut off tool grinds away metal faster than most grinders. Do the final grinding with a grinder to achieve a flat and well blended final surface.
Davidf is offline   Reply With Quote
Old 05-11-2015, 12:54 PM   #5
michael bustamante
michael bustamante's Avatar
and support that bumper!!
1967custom
michael bustamante is offline   Reply With Quote
Old 05-11-2015, 01:13 PM   #6
Jonlopes
Yeah, it is an impressive piece of steel. The scrap metal guy who comes through our neighborhood will be very happy.
Old 05-11-2015, 01:27 PM   #7
Orange Crate
Orange Crate's Avatar
If/when you get the bumper off, you might offer it up for sale. There might be another member that could use a heavy duty unit like that. Of course you would have to become a contributing member to sell items on this forum. There is always the CL also.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 05-11-2015, 06:54 PM   #8
Jonlopes
I will give the air cut off tool a try. Can you recommend one that is low in the CFM consumption? I only have a 33 gallon 120V compressor so I cannot continuously power the tools that ask for high CFM.
Old 05-11-2015, 07:09 PM   #9
hugger6933
You asked about a welding shop to remove it "properly", well they would just grind off the old welds as advised here and above. I would too use a die grinder but sometimes I forget that not everyone has a shop to work out of and is fully stacked with all tools that are needed for about any situation.[ I am blessed in that regard]. I think an electric angle grinder with either a 4 or 4 and 1/2 metal cutoff wheel would do fine if you have air problems. It will take several wheels to do this not matter what method you choose, just remember if using the electric angle grinder with the big blade, just don't turn the tool while using or the blade will break. Jim
hugger6933 is offline   Reply With Quote
Old 05-11-2015, 07:23 PM   #10
Jonlopes
Home Depot's brand of air tools (Husky) advertises just 4 cfm needed for their cut-off tool, my compressor can handle that (I think it is rated for 7) and if it cannot I can always return it.
Old 05-11-2015, 10:27 PM   #11
cericd
cericd's Avatar
I'll be watching this one. The PO of my truck did a similar thing minus the angle iron.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 05-12-2015, 11:17 AM   #12
Jonlopes
Yeah for a work truck they did a great job. I could tow a house with this bumper with no fear of anything coming apart. This truck, however, has graduated from a worker to a garage queen. I will try to remember to take pictures of my progress and also give insights from a guy who has not had to grind welds in the past (except on exhaust pipes).
Old 05-12-2015, 12:16 PM   #13
Davidf
If you go this route, be VERY careful. Electric motors have enormous torque. So, if you get a cut-off blade in a bind, you will either rip the tool out of your hand or probably break the blade. A broken blade can then do damage to you. Wear plenty of eye and face protection, wear heavy gloves and pray. For these reasons, I never use anything other than air powered cut-off tools. When the air power tool binds, it simply stops...no drama. I'm in construction, and have seen many people sent to the hospital (mainly for stiches) due to injuries caused by angle grinders fitted with cut-off wheels.
I don't think you will have much luck with your compressor.
Old 05-12-2015, 12:37 PM   #14
Jonlopes
Thank you for the advice. What would you suggest then? My compressor runs my impact, ratchet, drill, die grinder and chisel just fine so i am not going to spend $1000 for the 220 volt model plus paying the electrician to add a 220v outlet to the garage all just for this bumper project.
Old 05-12-2015, 12:46 PM   #15
Davidf
If it was me, I would buy a cheap Harbor Freight air powered cut-off tool. I would then go to Home Depot and buy a pack of cut-off wheels (4" I think). Then, I would find that the air supply is quickly depleted and I would spend time waiting for the compressor to catch up. After about 4 or so cycles, I would wait longer for the compressor to cool. You can regulate this process somewhat by limiting the speed of the tool (and thus CFM of air used).
That is what I would do. Eventually, you will get the stupid thing off your truck and still have all your digits intact. Whatever you do, just please be careful. Grinder injuries are worse than cuts as flesh is removed in the process...thus not much left to stitch up.
Old 05-12-2015, 12:55 PM   #16
Jonlopes
That sounds like a plan. The good thing is my little 120V compressor is at least oil lubricated cast iron as opposed to the oilless designs. I see you can get some of the "Better" brands of cut off tools for only about $55 (IR, Chicago Pneumatic, Air Cat, etc). Do you think they are better on air consumption than the $10 HF version?
Old 05-13-2015, 01:45 AM   #17
swamp rat
swamp rat's Avatar
If it was me i'd take a cutting tourch and cut the bumper off at the brackets, then start cutting as much of the unneeded brackets and angles off next to get them out of the way, then i's use a 4" grinder with good cuttoff wheels ( not harbor freight crap ) to grind the welds off, keep a hammer and chisel secured in Vice Grips handy.
If ya don't have a tourch you can always rent one.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-13-2015, 10:31 AM   #18
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I'm betting that these big step bumpers aren't from a prior owner installing them. Most of those big step bumpers came on these rigs as dealer options or installed at RV dealerships when people hauled those behemoth slide in campers.
So they were installed to last for the life of the truck.
Mine has one too... I love the big ol' step bumpers. Especially when a long bed truck with a big bumper like that is walking a newer Camaro or Mustang...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-13-2015, 10:46 AM   #19
kbill45@gmail.com
Post a picture of the bumper. If it is in good shape I will trade a new chrome one for it.
kbill45@gmail.com is offline   Reply With Quote
Old 05-13-2015, 11:06 AM   #20
mcbassin
Still Learning
mcbassin's Avatar
If it was mine, I would just use my electric angle grinder to grind the weld then break it loose.
Be careful to only grind the weld and not your frame. You shouldn't have to pay a weld shop to cut those welds.
mcbassin is offline   Reply With Quote
Old 05-13-2015, 11:45 AM   #21
leddzepp
Moderator
leddzepp's Avatar
I'd use whatever tool I already had handy, electric grinder or air tool. Just use common sense, gloves, and safety goggles. It ain't rocket surgery.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-13-2015, 11:50 AM   #22
Jonlopes
It is not that pretty, I was just going to scrap it. If anyone wants it they can have it I just do not want to have to try to ship this heavy thing.
Also the top portion of the license plate is blocked by the tailgate, I am afraid I am going to be pulled over some day because of this.
Old 05-13-2015, 12:59 PM   #23
kbill45@gmail.com
I believe that bumper is for another truck.
Old 05-13-2015, 01:40 PM   #24
Jonlopes
LOL, I believe the same thing, that is why I want it gone!
All joking aside, with the way the license plate mounts I think it was either mounted too high to clear the receiver or it is for something else.
Old 05-13-2015, 02:04 PM   #25
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Be VERY careful those brackets are lined up correctly when you bolt the bumper on. I bent mine long ago, likely because they weren't lined up, and therefore the faces on the mounts weren't flush with the bumper. As a result, there are two small spots that were pushed out to conform with the brackets.
That's one reason I'd like to confirm my bumper is OEM, as I'd like to have it straightened and re-chromed at some point. I believe it is OEM, because it was purchased decades ago after it had been re-chromed.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
