Old 05-11-2015, 12:58 PM   #1
Craftsmen
Pitman arm help please
Okay, I have a 1970 c10 short box with manual steering, time to go power. I went to advanced auto and purchased the power steering pump and gearbox for the 1970 c10. I read in the forum that I also needed the new rag joint which they had. I also read I need the pitman arm. They had to order the moog pitman arm because they didn't have one on the self. I got home held the new gear box in place and noticed I had to notch the front bumper bracket to clear, done. I bolted the new power box in place, noticed it takes four bolts not three. Done. The new power steering box spline shaft sets way closer to where the pitman hooks up. My question:
Can someone tell me the difference between the manual pitman arm and the power steering unit arm? Is it a short little thing or am I missing something?
For the pump mounting I'm installing a v8 instead of the six and plan on purchasing a serpentine kit. Probably buy the hoses from Paul's, etc.
Thanks for any help, always very much appreciated.
1970 C10 SWB
Craftsmen is offline   Reply With Quote
Old 05-11-2015, 01:04 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Pitman arm help please
im pretty sure its the same pitman arm
1967custom
michael bustamante is offline   Reply With Quote
Old 05-11-2015, 01:09 PM   #3
Craftsmen
Oh and forgot to mention my truck has all for wheels off the ground supported on the frame with jack stands. My truck have the ECE 4/6 lowering kit.
1970 C10 SWB
Old 05-11-2015, 01:14 PM   #4
FirstOwner69
FirstOwner69's Avatar
Rock Auto shows different pitman arms.
FirstOwner69 is offline   Reply With Quote
Old 05-11-2015, 01:17 PM   #5
Craftsmen
I just measured, the spline coming out of the power box is like 1-1/4" and the manual box is like an inch.
1970 C10 SWB
Old 05-11-2015, 01:35 PM   #6
67 cst swb
67 cst swb's Avatar
Moog K6130 Manual Steering
Moog K6131 Power Steering
Unfortunately, in this day of online cataloging. the Moog website does not show/tell me specifics in order to tell you the differences.
Here is where I bought my last one from.
http://www.afterhoursautoparts.com/s...spx?find=K6131
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-11-2015, 02:05 PM   #7
Craftsmen
Yep, ordered the k6131 moog. Someone said I may need the idler arm also? By the way those measurements in my prevoious post were diameter.
1970 C10 SWB
Old 05-11-2015, 02:42 PM   #8
Lou Boffa
Lou Boffa's Avatar
Yup, just did this, you will need to borrow the puller and a torgue wrench when re-installing.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 05-11-2015, 06:24 PM   #9
Craftsmen
Lou buffa were the two pitman arms the same length. splined hole center to ball stud?
1970 C10 SWB
Old 05-11-2015, 06:39 PM   #10
Lou Boffa
Lou Boffa's Avatar
I could not see a difference between them. I ordered and used a new Moog Pittman arm-recommended for a PS gear box, but could not see any difference between the new one and the old one--unless the spline count is different. That I did not check that. Both used a 1 5/16" nut.
Old 05-11-2015, 07:58 PM   #11
Craftsmen
Thanks a lot guys, you were a big help as always��
1970 C10 SWB
Old 05-12-2015, 08:46 AM   #12
big bad orange
big bad orange's Avatar
For some reason I thought some told me the spline count was different for power and manual.
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town"
big bad orange is offline   Reply With Quote
Old 05-12-2015, 02:40 PM   #13
kwmech
Power has a larger diameter spline
