Old 05-13-2015, 01:40 AM   #1
Mmorgan32
Mmorgan32's Avatar
Wheel fitment
Does anyone know if a 17 inch wheel will fit over disc brakes when switching to disc brakes from drums? I have a 70 c20 by the way
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 05-13-2015, 02:22 AM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Wheel fitment
A 17 should fit fine, the smaller 16s are stock on 3/4 tons so I wouldn't worry about it.
If you are concerned you can mock up the rotor and caliper inside the wheel to double check while the parts are still returnable.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 05-13-2015, 11:59 PM   #3
Mmorgan32
Mmorgan32's Avatar
Re: Wheel fitment
I've looked at a few kits to switch it to discs and they all say stock wheels won't fit. I had a 72 gmc with stock discs and 18s fit fine. I'd just rather go with a 17 and bigger tires on my current truck
Old 05-14-2015, 12:11 AM   #4
leftybass209
leftybass209's Avatar
Re: Wheel fitment
Stock 1970 and earlier drum brake wheels (3 nub steelies) won't fit. Modern 17's didn't come around until well into the disc brake era and should fit fine as long as they don't have a goofy backspace.
leftybass209 is offline   Reply With Quote
Old 05-14-2015, 12:13 AM   #5
Mmorgan32
Mmorgan32's Avatar
Re: Wheel fitment
What's a good backspace to get I don't want it to stic out just be even with the fender. I love my steelies they just sit in so far
Old 05-14-2015, 08:02 AM   #6
Mike C
Mike C's Avatar
Re: Wheel fitment
Disc brakes move the wheels out some. The reason the stock wheels don't fit disc brakes isn't the diameter but the shape of the center. It is not shaped to clear the caliper. 17's have the most tire sizes available and probably wheel choice as well.
Old 05-14-2015, 10:07 AM   #7
Mmorgan32
Mmorgan32's Avatar
Re: Wheel fitment
That's what I wanted to know. Thanks
Old 05-14-2015, 10:19 AM   #8
Lees68GMC
Lees68GMC's Avatar
Re: Wheel fitment
Mike's right the "Center section" and the "Hoop" are too close to clear disc brake calipers, sometimes even grinding on the calipers won't help. Also the back spacing is critical as the improper offset can cause the inner rim edge to hit steering knuckles, tie rods, sway bar, etc.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 05-14-2015, 10:40 AM   #9
Mmorgan32
Mmorgan32's Avatar
Re: Wheel fitment
Damn is that hitting the tie rod? Is that a 17 with a negative offset?
Old 05-14-2015, 10:20 PM   #10
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Wheel fitment
17" Hummer wheels fit on my 69 C20 with front disc brake conversion.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 05-14-2015, 11:58 PM   #11
Mmorgan32
Mmorgan32's Avatar
Re: Wheel fitment
That looks sick! Makes me not want to lower mine
