Old 05-13-2015, 10:21 AM   #1
DustyNova
425 cadillac in a 79 k5 blazer
Is this an easy swap? What transmission is the best to use and is the 425 a good motor
DustyNova is offline   Reply With Quote
Old 05-13-2015, 10:40 AM   #2
77 C-20 Scottsdale
Re: 425 cadillac in a 79 k5 blazer
It would be much easier to use a Chevrolet 454. The 454 has a LOT more horsepower and torque than the 425 Cadillac. It is a night and day difference between the two engines. The 454 would not require a transmission change, either.
77 C-20 Scottsdale is offline   Reply With Quote
Old 05-13-2015, 11:13 AM   #3
DustyNova
yeah but cant i tune it up to more power than it has and it will be lighter than the 454?
also where can i find an adapter for that and a 700r4 or th400
Old 05-13-2015, 11:23 AM   #4
jayoldschool
Moderator
If you're thinking, 425, you'd be crazy not to do a 500. Same everything space-wise. BOP pattern TH400 works, or, there are adapters for a Chev pattern 700R4 (but you'd better build it strong to take the torque).
jayoldschool is offline   Reply With Quote
Old 05-13-2015, 01:00 PM   #5
DustyNova
wouldnt a 425 get a little better mileage or what does a 500 get compared to 454? Bout the same?
