fuel line
I have a 55.2 gmc with a camaro sub. Small block with a mechanical fuel pump. Does anyone have pictures of the fuel line routing? I concerned about header clearance. Any advice would be helpful. Thanks
Re: fuel line
Sounds like your tank is still behind the seat? Here is how I ran mine from tank at back, inside frame rail, to filter next to stock fuel pump. If behind the seat I would run the line tight against cab floor to frame, then inside frame to mechicanical pump location. If you are concerned about heat, wrap it with some header wrap.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
