Need help identifying this axle
I just picked up a axle I was told was from a 48-52 Chevy 1/2 ton. I was told it came out of California and has been sandblasted before being put back together. It looks great and the breaks turn freely. I should be able to put some new lines on it and run the thing down the road no problem.
But, while the 5 lug thing is favorable. It should be a 6 lug. I did not pay much for it so I just loaded it up. I don't know if it was converted at some point. But, from a replacement parts standpoint I was wondering if you guys could help me out. Wheel mounting surface to wheel mounting surface is around 58.75 Outer spring hole to outer spring hole 29.5 Spring hole center to spring hole center is around 26 7/8. Lug pattern is 4.75x5 ![]() ![]() ![]() ![]() ![]() ![]() Thank you for any help
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
Re: Need help identifying this axle
It looks just like both of my axles that have 54 Car drums on them to get a 5 bolt on 4-3/4 pattern to run regular Chevy car wheels.
It actually looks like someone has redrilled the bolt pattern on the drums. I'd have to look at the axle I have off at home to tell if the measurements are the same. Can you post a straight on photo of the drum and a photo or two of the back side of the backing plate and spindle? Usually there spacers on the top two bolts that hold the backing plate if the backing plates have been swapped plus two extra holes because you have to drill two new holes above the old ones in the car backing plates to put them on truck spindles.
on my 1950 axle the measurements are close to yours. Because the frame narrows to the front the outer bolt holes are 1/4'' wider on tie rod side of axle as compared to drag link side of axle. they are 29'' and 29 1/4 '' outside to outside ubolt holes. spring center to spring center is 26 3/4''. mine still has 6 lug, wheel flange to wheel flange about
58 1/2''. back of backing plate to wheel flange about 4 1/4''
1957 3100 ![]() 1950 5 window |
#4 | |
Here is a shot of the drilled drum: ![]() Here is a shot of the spacers: ![]() More questions for those with more experience. So,this means I can replace the drilled drums with those from a XX Chevy XX(car)? This means that I have a 5 bolt car breaks from XX year car that someone just trying to be thrifty reusing the truck drums or do I have truck breaks that have been drilled to the 5 bolt pattern? Is there a difference internally between the truck and car breaks (no need to answer if I have car breaks and can use car drums)? Thank you.
Hollister Road Co.
The spindles are 53 up. You should have the truck brake as they used a truck drum and re-drilled it to fit. Measure the Ubolt holes, the fronts should be narrower than the rears. 29.5" is the AD frame width at that spot so you should have an AD axle and the stop locks are AD not Taskforce.
I suspect that they used later Bendix truck brakes with a car hub on an early axle that had Huck style brakes. |
