Old 05-13-2015, 03:33 PM   #1
chevytruckclassics
chevytruckclassics's Avatar
question about aftermarket radio? ways to secure it better?
so after days of debating with myself, i cut the dash in my 1967 k10 for a new radio. the bracket the holds the radio fit mostly snug in the hole, but it is a little lose and the radio can but moved a little. I put a piece of foam between the bottom of the radio and the ashtray to give it a little support. any idea on how i could secure the radio better? any suggestions would be appreciated. Thanks!
1967 Chevy K10 4 Speed
chevytruckclassics is offline   Reply With Quote
Old 05-13-2015, 04:06 PM   #2
SS Tim
SS Tim's Avatar
Re: question about aftermarket radio? ways to secure it better?
Typically any radio will have a support brace or bracket to the side or rear of the case. On aftermarkets its generally a heavy section like plumbers tape.
As far as foam goes its probably not a good idea for a number of reasons and I'd pull it out.
SS Tim is offline   Reply With Quote
Old 05-13-2015, 04:57 PM   #3
Jonlopes
Yeah, you have to make sure the foam is not covering any cooling holes. They sometimes put pretty powerful amplifiers in modern radios and they get hot.
Jonlopes is offline   Reply With Quote
Old 05-13-2015, 05:41 PM   #4
michael bustamante
michael bustamante's Avatar
there will be a stud in the back of the radio to attatch a piece of pipe strap onto. use that to secure it to the firewall
1967custom
michael bustamante is offline   Reply With Quote
Old 05-13-2015, 06:01 PM   #5
Custom/Ten
Custom/Ten's Avatar
Most of the little tabs you bend are made for a thicker dash, cut the holding case with a dremel disc so you can bend them farther. Hope that makes sense, don't cut off anything, know what I mean? I'm assuming you hooked up the strap. And yea ditch that foam!
Custom/Ten is offline   Reply With Quote
